does something need a poke?
squawk7000
Hi
my fibre upgrade order has been progressing.The order completed on my account on the 3rd May, but the switch at the cabinet went through this morning (9th May)
I am still getting the same download speed as when on ADSL at around 16Mb. Upload speed increased this morning to approx 1.8-1.9Mb. Speedtest done with a mac hard wired directly to the hub.
The estimated and current are:
Estimated line speed:40Mb (This may vary between 70.4Mb and 80Mb) - Checked on 2016-04-25 12:13:26
Current line speed:17 Mb
The hub one reports:
6. Data rate: 2000 / 39993
7. Maximum data rate: 17152 / 80228
8. Noise margin: 17.3 / 17.6
9. Line attenuation: 16.0 / 14.4
10. Signal attenuation: 15.9 / 14.4
I have tried disconnecting/reconnecting and restarting the hub.
Does something have to be poked at the PlusNet end?
Ken
Fixes: 165
Re: does something need a poke?
Taking a look, give me 5 mins.
 Chris Parr
 Plusnet Staff
Fixes: 165
Can you try a disconnect/reconnect and hopefully you should be up to speed.
 Chris Parr
 Plusnet Staff
squawk7000
Chris
Woohoo, your magic fingers have fixed it. Now getting in the region of 37Mb
Many thanks for your prompt resolution
Ken
