dlm reset
- Re: dlm reset
dlm reset
11-10-2019 10:08 PM - edited 11-10-2019 10:15 PM
can I get a dlm reset as dlm has kicked in and my latency has settled 4 times higher than it used to be
Re: dlm reset
12-10-2019 7:56 PM
Re: dlm reset
22-10-2019 10:28 PM - edited 22-10-2019 10:29 PM
was one done as my latency/ping now is 21 when it was 4 before
Re: dlm reset
23-10-2019 12:01 PM
Hi @louiswood, thanks for getting back to us.
Although you have concerns with your ping, I can assure you that a ping of 21 is fairly good and around the range we would expect to see customers achieving. With that being said, testing the line does show you are in sync at 66.6mb which is just below what we would expect for your line.
I'd advise getting connected into your test socket and if the issue persists, please report the fault here and let us know once done so we can investigate further.
Re: dlm reset
23-10-2019 3:27 PM
Re: dlm reset
23-10-2019 4:06 PM
Hi @louiswood, thanks for getting back to us. As mentioned we are seeing your speed running lower than expected, can you please follow the steps advised and let us know once done so we can investigate further.
