did anyone else just lose connection ?
St3
Aspiring Champion
Fixes: 5
my net just disconnected briefly ... i hope its not going to be another few days off downtime, this looks like the old network i could be wrong ?
You are currently connected to gateway ptw-bng01.
This is located in Telehouse West.
Riza
Re: did anyone else just lose connection ?
Yep got assigned a new ip on the old network.
Eventually they've listened 😀
And yes that is the old network.
Network ping graphs also confirm this.
rongtw
Fixes: 12
Yup ste , thats the OLD network Wink   must be moving people back untill they find a fix for the NEW  Roll eyes
nbk
Oh I guess they're doing it to numerous people then...personally I'd have preferred the issues actually got fixed rather than a work around :/
Riza
Well the option to buy a static ip has gone and tickets suggest that we've been applied the static ip
St3
Aspiring Champion
Fixes: 5
i didnt request a static ip and dont want one either. Well its that they are looking into things tho Smiley
nbk
Yeah I saw a ticket with the static applied and it shows so in my profile...I just hope that wasn't charged for :|
Riza
Probably temperamental until a fix is made.
Dave Tomlinson - IE - Generic
1:53pm, Friday 2 Sep 2016
Added components to account: (ADSL Residental single static IP)
Thanks Dave Smiley
nbk
But I'm VDSL2, not ADSL! Wink
Riza
I am also on VDSL. Tongue
But some people on copper got moved to the new network as well so I guess it's just a category that all affected people are placed under.
nbk
On my copper-aluminium-fibre hybrid internet ( Wink ) I've noticed speed tests slowly trail off from 75 down to 71...a bit odd
Riza
Probably the loss in sync caused bt dlm to think there was a line error and lower it down. Let it rest for a week for dlm to raise it again..
nbk
Didnt lose sync, was just the router that lost connection, the modem stayed connected
St3
Aspiring Champion
Fixes: 5
i checked by going into cmd/ ipconfig/all
Im not on a static ip Smiley
Hopefully bob will update us all soon, as he is the main man running the show
Riza
That's a static ip held by your routers dhcp if you do ipconfig
You need to restart router and determine if ip changes
