considering fibre need advise please
gizmo666
hi folks i'm thinking about upgrading from adsl to fibre
but i have a couple of questions if someone can advise me
1 im using a bt 5 hub do i need the new router?
2 how long does the changeover process take?
3 is there a big difference?
4 whats involved with installing on my part?
thanks in advance folks
3 REPLIES 3
VileReynard
Champion
Fixes: 17
Re: considering fibre need advise please
It depends.
Plusnet could give you a speed estimate.
On ADSL I got 8Mb/sec, on fibre I get 70Mb/sec
If you are a few hundred yards from the appropriate cabinet (not necessarily the nearest one) and the copper telephone wire doesn't go all round the houses before it gets to you, you ought to get a decent speed.
No guarantees.
Big difference if you do big downloads and aren't over-reliant on Wifi.
Fixes: 99
@gizmo666
The Hub 5 will work fine. It may automatically reconfigure, if not the new settings will be found here https://www.plus.net/help/broadband/broadband-connection-settings/
Changeover should take around an hour
If you put your phone number in here it will tell you the range of speed that you should get. https://my.btwholesale.com/includes/adsl/adsl.htm?s_cid=ws_furls_adslchecker
Apart from possibly having to reset the router there is nothing else you need to do. If you take the ‘free’ Hub One, which under the hood is a Hub 5a in an ugly case then you just plug it in and it auto configures.
gizmo666
thamks for that got my oreder in
