connection issues
masive38
Browser
connection issues
I keep loosing connection on my fibre broadband this problem happened a few months ago but the same thing is happening again has anyone else had the same problem?
1 REPLY 1
Beyhive
Aspiring Champion
Fixes: 43
Re: connection issues
Hi @masive38,
I have checked your connection and I could not find an issues with it. The connection has been fairly stable with download speed of 79.9Mbps
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 79.9 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 348.6
Upstream Rate Assessment Very Good
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2019-09-28T13:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 79.9 Mbps 79.9 Mbps 79.9 Mbps
Up Stream Line Rate 19.9 Mbps 19.9 Mbps 19.9 Mbps
Up Time 532.0 Sec 900.0 Sec 899.4 Sec
Retrains 0.0 3.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-10-11T12:08:22Z 2019-10-11T12:23:22Z
Ingress Code Violation 3 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Are you noticing the issue solely on wireless devices or wired also? How often does it drop for you?
 Faris
