connection interupted during file transfer over workplace VPN
- connection interupted during file transfer over wo...
10-06-2019 11:19 AM
Good Morning, i hope somebody can offer advice regarings my connection through Globalprotect VPN. i have recently signed up to Fibre Extra and now have an excellent connection to the internet and streaming VOD(such as netflex), however i need to connect to my workplace shared drives to occasionally download and upload files of medium size(1-3mb), this is achieved through a work laptop running Globalprotect VPN.
if the file is larger than a few kb, then windows explorer reports connection interupted and requests i try again, i can see all the shared drives and the files within but i am unable to copy to or from, if i share my mobile phone connection and connect through Global protect then files copy with no problems- there is also n problem from other wifi locations. My company ICT have advised that there must be an incompatible setting either with the Plusnet One Hub or with Plusnet, i have enabled and disabled port clamping on my router with no success,
any advice is greatfully received.
Re: connection interupted during file transfer over workplace VPN
10-06-2019 12:55 PM
10-06-2019 1:44 PM
OK, thanks for looking into it, apart from Globalprotect i have no reasons to suspect any issues with my connection, the VPN settings are locked out of my control with my comany IT authorised to make changes, which they say is all configured correctly. i will try the company IT and see if they have any further suggestions. thanks
10-06-2019 2:27 PM
