connection drops
rongtw
Fixes: 12
connection drops
@Gandalf could you post my connection logs please Smiley
for a test i went to a dynamic IP but for last 2 nights after 00.00  my connection drops until 06.00  ?Huh
and i get this from my router
May 4 00:42:09 pppd[536]: Connection terminated.
May 4 00:42:09 pppd[536]: Modem hangup
May 4 00:42:54 pppd[536]: Timeout waiting for PADO packets
May 4 00:43:53 WAN Connection: Fail to connect with some issues.
May 4 00:44:09 pppd[536]: Timeout waiting for PADO packets
May 4 00:44:09 pppd[536]: Connected to a0:f3:e4:34:d9:06 via interface vlan3880
May 4 00:44:09 pppd[536]: Connect: ppp0 <--> vlan3880
May 4 00:44:10 pppd[536]: CHAP authentication succeeded
May 4 00:44:10 pppd[536]: peer from calling number A0:F3:E4:34Cheesy9:06 authorized
Fixes: 508
Re: connection drops
Sure thing, will post up within 1 hour. Just on my way to the office. Smiley
Fixes: 508
Thank you for your patience.
Here you go:
There's the odd drop here and there, but seems pretty stable?
Testing your line, the test is failing with an active MSO:
Problem Explanation: [OD505] This circuit is affected by an Openreach PEW. The Incident detail is as follows- Incident ID: ############ Start Date: 2017-05-04T08:35:46.000+01:00 Estimated Completion Date: 2017-05-03T02:00:01.000+01:00.
Resolution/Recommendation: Please inform the End User of this.
rongtw
Fixes: 12
@Gandalf
this is what i saw this morning and yesterday ?  weird how same problem same time two successive days tbb graph.JPG
and from router ASUS DSL AC68U  But it says uptime is 2 days 22 hours 25 minute(s) 27 seconds  Crazy2
Fixes: 508
It's possibly caused by the MSO.
Let us know how it goes over the next couple of days.
rongtw
Fixes: 12
will do thanks Thumbs Up
