connection drop 1-2 times / day
- connection drop 1-2 times / day
01-06-2018 2:18 PM
hello
for the past week or so my connection has been dropping once/twice almost everydays
phone line checked and looks ok
router in master socket
computer wired
router goes flashing orange ( just like when you restart it ) and after a few loggin attemps ( 2 or 3 ) connection is back
any check available?
thank you
Re: connection drop 1-2 times / day
01-06-2018 3:50 PM
Moderator's note:
Unhelpful post removed.
Forum Moderator and Customer
01-06-2018 5:34 PM
Hi Sebjo, it's dropping a few times per day from what I can see. Diagnostics don't show up any obvious causes so can you try the checks here please? https://goo.gl/tu2WWu
Let us know how you get on. - Adam
01-06-2018 5:46 PM
all that already checked , no phone noise, master socket ,swapped micro filter , all wire correctly connected
01-06-2018 6:24 PM
I don't know if you will get a further reply from @adamwalker tonight. If you don't, report a fault at https://www.plus.net/apps/kbdfaults It takes a bit of your time and costs you nothing, but makes Plusnet aware of your issue, they have to look at it, and gets the issue into the queue for action.
02-06-2018 11:05 AM
Thanks for reporting that via your account @sebjo.
I've made sure that's in hand with our suppliers and our faults team should be in touch once we receive further updates from our suppliers.
I hope this helps.
03-06-2018 2:36 PM
thank you ,on this sunday my connection dropped again , twice in less than 2 hours ,maybe even less than an hour.
03-06-2018 2:37 PM
BrightonRock thank you , it is done
04-06-2018 11:28 AM
I have looked into the fault which was raised by Harry and have provided an update on this ticket on your account.
Please give it a read through and reply to it with the information requested if you are still experiencing this issue.
