configuring tg582n fibre router for humax hd pvr
- Re: configuring tg582n fibre router for humax hd p...
20-02-2015 5:23 PM
Any help greatly appreciated.
Re: configuring tg582n fibre router for humax hd pvr
21-02-2015 2:54 AM
Is your dongle plugged into the USB port, or the ethernet port?
The former doesn't sound like something I'll know anything useful about, but the ethernet side is probably going to be pretty straightforward. What network settings do you have in the Humax? Is it set to obtain its IP address by DHCP? Is your router set up to run DHCP? These are both normally defaulted to yes. If it's using DHCP, can you see it in the DHCP table on your router config web pages?
As a starting point, I would run an ethernet cable between your Humax and your router and see if it works. That will tell you if it's a basic config error or a wireless/dongle problem.
Do you have some more details on your dongle (make/model etc.)? Is it designed to do what you're trying, or is it targetted at laptop/pc use? Do you have a USB socket on your TV?
The more questions you can answer, the more likely you'll get something useful.
Also, this may be in the wrong forum, as I'm not sure it's going to turn out to be fibre specific.
21-02-2015 11:55 AM
Humax support seem confident that the problem is one which they frequently see and that the solution lies in changes to router config, but as they are not familiar with the tg582 router they cannot advise how to change settings.
I posted in Fibre because the solution seems to be router related, and more likely to get a response from Plusnet staff or other knowledgable customers whofrequent the forum. If a moderator wants to move this to a more suitable location I would have no problem with that
21-02-2015 3:22 PM
22-02-2015 1:47 PM
22-02-2015 4:27 PM
Seriously, whilst I appreciate the advice, I was hoping it to be more along the lines of my original post, I.e. how to configure ports.
22-02-2015 8:38 PM
I use these: http://www.amazon.co.uk/TP-LINK-PA411KIT-Powerline-Adapter-Starter/dp/B0084Y9N3O/ref=sr_1_1/278-4711...
podman
22-02-2015 8:52 PM
Seriously, I would suggest either borrowing a long ethernet cable, or temporarily moving the router and/or PVR closer together on a shorter cable to get the new firmware (you might also be able to achieve a firmware update via download onto a USB (data) stick, then sticking it in your PVR and accessing/updating via PVR menu - then trying the dongle again after the update.
I was also going to suggest the homeplugs mentioned by podman as an alternative solution. They're really very good. I use them to connect my PVR via ethernet.
Also, check your routers' DHCP table, as suggested in my original post, to see if your PVR has picked up an IP address. You can then ping that address from your laptop/whatever to check local connectivity.
22-02-2015 10:22 PM
Quote from: maranello Anyone know where I can get ~45 feet of ethernet cable?
Surely you could temporarily move the box to the router just to try Seahog's suggestion! It doesn't need an aerial connection while you do so. If you have a PC monitor with a HDMI connection you wouldn't need to move the television.
22-02-2015 10:29 PM
23-02-2015 11:26 AM
I don't have a PC monitor with HDMI, but the Humax does have SCART and RGB output, either of which I could use to connect the Humax to a portable TV if I were to temporarily move it closer to the router. Moving the main TV would be more inconvenient as it is mounted on a wall.
A permanent ethernet connection via homeplugs sounds like an ideal solution, but since I already have a good wireless signal the extra cost does not seem worthwhile given that the use would be occasional only. I do have other options for catch-up TV, such as connecting my laptop to the TV via HDMI, and I don't know yet how extensive (or more likely limited) the Humax TV portal is, so homeplugs don't seem a particularly cost effective solution if the same result can be achieved by either getting the wireless dongle to work properly, or occasionally using the laptop as I have done already.
The least cost and least disruptive option still seems to be changing the router configuration to allow the Humax to connect to the internet beyond the router, and I will try this approach first.
If successful with any of the suggestions I will update this thread.
24-02-2015 10:50 AM
Went through the setup on the Humax again, firstly tried to configure LAN settings, not expecting it to work as I thought this only applied to an ethernet connection. Lo and behold, when I tried to apply the new settings the message appeared that the network connection was unplugged. So reset back to original. Then re-entered wifi configuration and re-entered wireless key and applied settings. Same as before, message appeared that connected to network. Tried to access the portal and did not work first time, but tried again a minute later and it connected. Success, no change to router settings, no need to purchase ethernet cable or move equipment.
Just as well, really, as the choice of apps on offer was somewhat limited (iPlayer, youtube, BBC news, BBC sport, Twitter, Internet radio, a few others), and the interface rather basic. Glad I didn't put in too much effort getting it working.
Thanks anyway to all those who offered suggestions and advice, much appreciated.
24-02-2015 1:45 PM
http://www.amazon.co.uk/Network-Cable-CAT5e-Patch-Ethernet/dp/B001GS39MQ/ref=sr_1_1?ie=UTF8&qid=1424...;
At this price it can be a useful thing for testing / temporary connections
