changed package type to fibre - what next?
- Re: changed package type to fibre - what next?
23-02-2016 2:38 PM
Have just upgraded online from BB to fibre.
I can see my house has fibre coming in from some time ago but I have no idea what condition the cables are in etc.
Can anyone explain how it works? Will Plusnet contact me and arrange to send out an engineer?
Can I keep existing broadband until switchover?
thanks
Gus
thanks
Gus
Message 1 of 7
(1,031 Views)
6 REPLIES 6
23-02-2016 2:45 PM
I see some confusion
If your house has fibre already it is probably Virgin cable and you have ordered FTTC which comes down the existing copper wires
Message 2 of 7
(694 Views)
23-02-2016 2:49 PM
it's also likely to be a self install so you will get a router through the post but are unlikely to get an engineer visit - they will just do the work at the cabinet to switch you over.
Message 3 of 7
(694 Views)
23-02-2016 2:54 PM
Thanks guys for responding.
Just had a look. There is a box with "NTL" written on it and a lead going to the usual phone socket.
Others in the street have Virgin but they stated £10 a month for a static IP. I want my static IP and I don't want their (Virgin) TV bundles so decided to stick with PlusNet.
Ok, I assume they can check that everything is operational without a site visit then?
Message 4 of 7
(694 Views)
23-02-2016 3:01 PM
NTL is what is now Virgin
Message 5 of 7
(694 Views)
23-02-2016 9:53 PM
It's also not fibre, it's coax.
Message 6 of 7
(694 Views)
24-02-2016 7:51 AM
it's fibre to the cabinet, just like BT.
the only coax bit is from the cabinet to the house, whereas BT is copper from the cabinet to the house.
Message 7 of 7
(694 Views)
