capped speeds?
FIXED- Subscribe to RSS Feed
- Re: capped speeds?
- « Previous
- Next »
Re: capped speeds?
01-10-2018 12:20 PM
sorry forgot attachment!
Re: capped speeds?
02-10-2018 11:44 AM
Re: capped speeds?
02-10-2018 12:37 PM
Yes - locked on 34.999 Mb/s now. Thanks for your concern. Jeff
Re: capped speeds?
02-10-2018 8:58 PM
Re: capped speeds?
03-10-2018 8:28 AM
Most grateful for the support from you and your colleagues. OR due to start about now, so hoping for a favourable outcome! Regards Jeff
Re: capped speeds?
03-10-2018 12:34 PM
Hi!
Very thorough search by OR engineer who found copper/aluminium joints at the distribution pole; water ingress had contributed to a voltaic noise generator.
Now humming along at 53-54Mb/s.
Let's hope it is a 'permanent' fix!
Thanks greatly, Jeff
Re: capped speeds?
03-10-2018 5:44 PM
Hi Jeff.
I'm glad to hear that the engineer was thorough, fingers crossed it is a permanent fix!
If you want to pass on your thanks to the engineer I'd fill out this form: https://www.formwize.com/run/survey3.cfm?idx=505d040e0a0e0c
Let us know if you need any further help from us.
- « Previous
- Next »
