capped speeds?
FIXED- Subscribe to RSS Feed
- capped speeds?
30-05-2018 4:46 PM
On my PN contract FTTC many years ago, I was delighted to obtain d/l speeds of 55 Mb/s. After a few years I phoned to include phone landline and afterwards, my speeds dropped to 50Mb/s inspite of verbal assurance that my BB would be 'unaffected'. PN retort was 'well you changed your contract'. OK no great deal.
Nowadays day in day out, 24hrs 7 days, d/l speed is 34,999Mb/s over the year, including months when I am abroad. . 3 OR site visits confirm the speed and find no faults.
The speed limit is suspiciously close to 35 Mb/s and shows every sign of being capped.
At present the Dynamic Line Management (DLM) profile for a UK Fibre-to-the-Cabinet (FTTC / VDSL2) based broadband line requires an Openreach engineer to reset. Is PN close to being able to reset the DLM itself?
What is the current position on DLM?
Thanks, Jeff
Fixed! Go to the fix.
Re: capped speeds?
30-05-2018 6:11 PM
Moderator's note:
Thread moved from Broadband to Fibre Broadband.
Forum Moderator and Customer
Re: capped speeds?
30-05-2018 6:19 PM - edited 30-05-2018 6:20 PM
Plusnet can make a request for DLM to be reset only if the line is banded so you will need to get confirmation that it is first before the request for the reset can be made.
One of the Plusnet Forum staff will be able to see if the line is banded or not
Re: capped speeds?
30-05-2018 7:03 PM
many thanks for the comment. How do I get a forum staff member to check for banding? (I have not heard of that!).
Re: capped speeds?
31-05-2018 11:57 AM
Sorry to hear your speeds have dropped.
I've tested your line and I can see the speeds are low but this isn't due to DLM as shown below
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 35.0 Mbps |
Upstream Speed | 12.4 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 592.2 |
Upstream Rate Assessment | Low |
Downstream Rate Assessment | Low |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | Errors Observed |
Interference Duration Longest Occurrence | From 13:45 to 16:30 |
Interference Location | Customer Premise |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-44M Downstream, Interleaving High - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2018-05-18T12:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 35.0 Mbps | 41.1 Mbps | 35.7 Mbps |
Up Stream Line Rate | 12.1 Mbps | 12.6 Mbps | 12.4 Mbps |
Up Time | 867.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-05-31T11:34:54.766+01:00 | 2018-05-31T11:49:54.766+01:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
I'd recommend raising a fault here so we can take a look further.
Re: capped speeds?
31-05-2018 1:43 PM
Many thanks for your swift response to my query and line test; at least it is clear that it is not a DLM imposed restriction. I do find it strange that my measured speeds never vary - constant to 1 in 35,000 Mb/s, over the 24hr day, which would seem to imply that stochastic effects such as interference are improbable.
I should say that i have had 3 Open Reach visits and the last's comments were that 'the line was good, no apparent problems and that if the cabinet checks out, there wasn't anything he could do'. (My neighbour on the same pole gets approximately the same d/l speeds with Sky).
I shall not raise a fault at this time as the engineers seem to conduct the same limited tests on each visit, thanks.
regards Jeff
Re: capped speeds?
01-06-2018 10:48 PM
This part here 0.128M-44M Downstream quite clearly shows the line is banded it should state 0.128M-80M.
Re: capped speeds?
02-06-2018 8:00 AM
Thank you Terranova for that observation! Can PN respond to this PLEASE? Jeff
Re: capped speeds?
02-06-2018 1:24 PM
Whilst there is banding on the line it's not restricting the current speeds as the router is only syncing at 35mbps. We'd never request a reset for this as it wouldn't make any difference
Re: capped speeds?
02-06-2018 1:43 PM
router report attached , in case this helps. More confused now as PN previously said 'no banding' detected.
Re: capped speeds?
02-06-2018 5:02 PM
I do apologise for any confusion here. While there is banding on your connection on our suppliers side, as advised by @MatthewWheeler, this is not actually restricting your speeds, as your sync speed is quite a bit below the banding that is currently in place on the connection.
Re: capped speeds?
02-06-2018 9:23 PM
Thanks, yes, I understand. Is it possible to get a time profile of interference on the line over 24 hrs so that i might try to identify the source.
The only change in my environment in the last 2 years since I last attained 50Mb/s d/l has been the installation of a solar farm 300M distant. I wonder if the radiated noise could be due to their synchronous converters or maybe a vhf monitor. Is it a BT/OR (or other) responsibility to monitor such environmental emissions?
Thank you for your patient support, Jeff
Re: capped speeds?
02-06-2018 9:24 PM
Whilst a DLM reset at this stage won't do anything maybe the reason why the OP is only getting 35Mb on a Fibre extra account with a 56Mb max attainable should be looked into?
the line on Interleave with a 10db+ SNR suggests there is some interference / noisy line or other issue(s) DLM isn't happy with forcing the speed down, once that is solved the speed should rise for the Banding to be removed and closer to the Max attainable.
Re: capped speeds?
02-06-2018 9:33 PM - edited 02-06-2018 9:34 PM
I believe but I could be wrong that Openreach can investigate interference from outside sources and make a request for them to make changes should they find they are the cause of the Interference, but I don't believe they can enforce anything as I say could be wrong about the whole thing, something to ask Plusnet about if you feel that is where the problem may lie there is for sure something causing DLM to increase the SNR to a high level and add interleving.
Re: capped speeds?
03-06-2018 8:06 AM
Thanks - Hoping I can get a 24hr profile of noise. One thing about a solar farm is that it should be silent from sunset to sunrise!! Also, I would have expected OR to notice a regional cluster of problems.
