can you reset my profile please?
superuser
Currently
Estimated line speed:There's no speed estimate currently held on your account.Current line speed:48.8 Mb
It's gone down from near 70 recently due to replacing router and power outs
If you could try a remote reset, that would be appreciated
geek26
Re: can you reset my profile please?
Sadly as it currently stands plusnet are unable to reset profiles for fibre lines, as long as the connection stays stable now it will slowly begin to work it's way back up
James
SpendLessTime
Aspiring Hero
Fixes: 82
@superuser
Have you ran the BTW speedtest and then completed the "Run Further Diagnostics" after the speed test finishes? This will show your BTW IP profile which you need to know in addition to the Plusnet Current speed
http://www.speedtest.btwholesale.com/
Fixes: 167
@superuser
As has been mentioned, I'm afraid ISPs can't reset or alter line profiles on fibre circuits. This will only be done by an engineer following a visit once they've resolved a fault.
Testing your line shows the profile is correct in relation to the sync speed or 51.6Mb/s (the profile is now 51.4Mb/s).
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0001
Description GEA service test completed and no fault found but unable to check for customer equipment connected to modem.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 51.6 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 611.3
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence From 00:45 to 00:00
Interference Location Customer Premise
Customer Traffic Level Upstream and Downstream Traffic Detected
Profile Name 0.128M-80M Downstream, Retransmission High - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2017-02-01T15:00:00
 Chris Parr
 Plusnet Staff
superuser
Thanks all
I'll sit tight and see how it is in a few weeks
