cable length
- cable length
cable length
10-02-2018 2:53 PM
how am i getting the same sync speeds using a 10 meter rj11 and a 1 meter rj 11 to the hub one ?
surely there would be a difference ?
6. Data rate: | 20000 / 73169 |
7. Maximum data rate: | 26805 / 73223 |
8. Noise margin: | 9.5 / 6.0 |
9. Line attenuation: | 17.6 / 14.0 |
10. Signal attenuation: | 17.4 / 14.0 |
attenuation has increased but still the same sync ? this is with the 10 meter rj11
Re: cable length
10-02-2018 3:20 PM
Re: cable length
10-02-2018 5:36 PM
there both decent cables but i would of thought if u used a 1 meter cable you would sync a lot higher the a 10 meter one and have no difference at all using any of them
Re: cable length
11-02-2018 9:27 PM
5. DSL uptime: | 0 days, 00:22:37 |
6. Data rate: | 20000 / 64267 |
7. Maximum data rate: | 20481 / 75825 |
8. Noise margin: | 6.1 / 6.0 |
9. Line attenuation: | 16.9 / 13.8 |
10. Signal attenuation: | 16.8 / 13.8 |
11. Data sent/received: | 1.6 MB / 5.0 MB |
dlm kicked in but for the better eventually will increase my speeds a little bit more latency gone up to but it was only me messing with the cable twice lol dlm sucks big time really as it cant tell if theres a problem or just resetting the router
Re: cable length
12-02-2018 2:38 PM
max data rate creeping back up
5. DSL uptime: | 0 days, 17:39:32 |
7. Maximum data rate: | 20525 / 76287 |
8. Noise margin: | 6.2 / 6.1 |
dlm u suck
