cable length
iangilf
cable length
how am i getting the same sync speeds using a 10 meter rj11 and a 1 meter rj 11 to the hub one ?
surely there would be a difference ?
6. Data rate: 20000 / 73169
7. Maximum data rate: 26805 / 73223
8. Noise margin: 9.5 / 6.0
9. Line attenuation: 17.6 / 14.0
10. Signal attenuation: 17.4 / 14.0
attenuation has increased but still the same sync ? this is with the 10 meter rj11
4 REPLIES 4
Browni
Aspiring Hero
Fixes: 60
Re: cable length
Line attenuation of 14dB would put your line length at 400m+, an extra 10m shouldn't have much affect unless it's of poor quality.
iangilf
Re: cable length
there both decent cables but i would of thought if u used a 1 meter cable you would sync a lot higher the a 10 meter one and have no difference at all using any of them
iangilf
Re: cable length
5. DSL uptime: 0 days, 00:22:37
6. Data rate: 20000 / 64267
7. Maximum data rate: 20481 / 75825
8. Noise margin: 6.1 / 6.0
9. Line attenuation: 16.9 / 13.8
10. Signal attenuation: 16.8 / 13.8
11. Data sent/received: 1.6 MB / 5.0 MB
dlm kicked in but for the better eventually will increase my speeds a little bit more latency gone up to but it was only me messing with the cable twice lol dlm sucks big time really as it cant tell if theres a problem or just resetting the router
iangilf
Re: cable length
max data rate creeping back up
5. DSL uptime: 0 days, 17:39:32
7. Maximum data rate: 20525 / 76287
8. Noise margin: 6.2 / 6.1
dlm u suck Tongue
