btw speed test
robbiecollie
btw speed test
BTW speed test is constantly showing zero download speeds has anyone experienced this problem
3 REPLIES 3
Chris
Legend
Fixes: 169
Re: btw speed test
That sounds odd, have you tried any other speedtesters?
robbiecollie
Re: btw speed test
Yes have tried other speed tests (Speedtest.net & Thinkbroad)they both function correctly
tiffy
Re: btw speed test
I also have been experiencing issues recently with BTW speed tester when using my default browser, Firefox.
Since a few weeks ago I have noted that a warning window appears after the test is selected to the effect that Adobe Flash must be activated and this may cause slow down issues with Firefox, once accepted, the test runs.
However, the DS data speed returned is definately incorrect, much lower than my TBB desktop indicator shows during the test and much lower than other speed test sites such as TBB, they all return the correct DS data rate of approx 35 Mbps which is to expectation for my contract / line.
When I run the BTW speed test using IR11 browser the correct DS data speed results are returned every time.
Looks like the issue is with Firefox, something has changed with a recent update ?
Have not tried any other browser to date.
There is a thread regarding this issue on the kitz forum.
