bt home hub5
elias1
bt home hub5
hello I am about to get plusnet fibre installed an I will be using a new bt hub5 will the open reach engineer  connect an configure the bt hub 5 for me or will I have to do it my self and if I have to do it myself how do I go about doing also I will be using tp power link adaptors with a pass over to connect my smart tv an my laptop via Wi-Fi any and all help an advice is welcomed
adie:green removed unneeded poll]
rubble3
Re: bt home hub5
I have just moved to Plusnet Fibre plus and have used my BT Home hub 5.
Just follow the info. on this thread it is easy to do yourself:-
http://community.plus.net/forum/index.php/topic,135840.0.html
Fixes: 33
Re: bt home hub5
As above, you will need to enter your PN username and password into the HH5, Openreach did not come out for me, but then I was swapping from BT to PN, so Openreach had set up my original Fibre connection.
