broadband speed Your download speed 36.9 Mb Your upload speed 10.5 Mb
- Re: broadband speed Your download speed 36.9 Mb Yo...
03-06-2015 5:35 PM
Your download speed
36.9 Mb
Your upload speed
10.5 Mb
Why is my speed so slow. I waited months without a telephone line or internet service for you to install your hitech equipment, so why are my speeds so slow?????????/
36.9 Mb
Your upload speed
10.5 Mb
Message 1 of 4
(897 Views)
3 REPLIES 3
Re: broadband speed Your download speed 36.9 Mb Your upload speed 10.5 Mb
03-06-2015 5:52 PM
Can you run the speedtest at http://speedtest.btwholesale.com/ and after the test choose ‘Further Diagnostics’ and post the speeds and the profiles that this gives.
Also find your estimated speed at http://www.dslchecker.bt.com/adsl/adslchecker.welcome and enter your telephone number, and post that
With that information it will be easier to see what (if anything) is going wrong.
Also, if at all possible run the tests on a wired connection to the router; the use of wireless can considerably reduce speeds.
Message 2 of 4
(679 Views)
03-06-2015 6:06 PM
That seems to be spot on in terms of product.
I'd have expected the upload to be a little faster, but based on the current sync rate (and estimate) that too is acceptable.
If you could please provide the actual throughputs, from the link above, that would help us. Thanks.
Message 3 of 4
(679 Views)
03-06-2015 6:36 PM
Edit 2:
I've just made a change to the account for you which shouldn't have fixed anything. However, can you please drop the connection and re-connect. If this sorts it, please post back so I can report on a potential problem.
Ta.
Ta.
Message 4 of 4
(679 Views)
