broadband slow
thackie2015
broadband slow
I have fibre unlimited up to 38mb, my line speed is 26.0mb,  but the line has been constantly at a speed of 12.9Mb, I have reset my router but there’s been no change, I’m not happy I’m not getting the speed I’ve signed up for.
I have followed all the advice in the troubleshooting section even raised a question :
170695802
but the reponse just says its been escalated  - been like that since 18/3/18 I know I live in the Borders which has slow internet but surely it must be better than this . Can someone tell if there is a fault or what can be done to improve things.
Cheers
5 REPLIES 5
thackie2015
Re: broadband slow
Engineer on the way Smiley
adamwalker
Fixes: 221
Re: broadband slow
Glad to see this is in hand and I hope the engineer is able to get this sorted for you tomorrow.
 Adam Walker
thackie2015
Re: broadband slow
Engineer says "I am currently working with a PlusNet hub which is not FTTC compatible hence why I have an Openreach ECI modem also"
Please can I have a Plusnet Hub which is compatible
Kevin
adamwalker
Fixes: 221
Re: broadband slow
Hi there, the router we've sent you is FTTC and also ADSL compatible, and is intented to be used along side the Openreach modem.
 Adam Walker
thackie2015
Re: broadband slow
Hi adam,
I have added detail to my question as mentioned previously.
Thanks for your help
