broadband password
- Re: broadband password
broadband password
01-06-2018 10:58 PM
01-06-2018 11:11 PM
I would guess that one or more of the settings in your new router is wrong - but not knowing what it is can't say any more.
And now that you have changed the password in the members centre, unless you change your old router to the same, or reset it by pressing the button in the pinhole at the rear for long enough it is still set to the old password.
01-06-2018 11:23 PM
And im resetting it all the now to hope it works. I've also connected the openreach modem to a pc via an Ethernet cable and set up a connection, but that also failed. So I'm pretty sure the password isnt the same as the one to log into this on, or it take a while to update maybe?
01-06-2018 11:44 PM
Its the password to the member centre that needs to be in the router, which may be different to this forum.
TP link AC1200 does not help much, there should be a bit more info - which one ?
01-06-2018 11:55 PM
I'm still thinking it's the password thats the problem. Reset my old router and modem, re connected it and it had internet connection, the username was nothing like my name though. Then ut dropped out of connection.
02-06-2018 12:23 AM
