blacklist advice
- blacklist advice
blacklist advice
25-06-2015 2:59 PM
coud'nt not login so checked with a friends account they coud'nt log in either. so I connected to
the forum miniclip on my tablet and was able to log into the forum I guess the IP address was banned.
upon looking into this as never been banned from a forum miniclip went to a site to check this
http://whatismyipaddress.com/blacklist-check
and see my public ip address is blacklisted by 2
pbl.spamhaus.org and zen.spamhaus.org
whats this all about I have no idea. thanks
Re: blacklist advice
25-06-2015 3:07 PM
If you're asking how to get around it, it depends on whether you have a static IP address or not. But I will say no more
25-06-2015 3:11 PM
a player was cheating.
just searched google and found this
Help! My IP address is on the PBL! What should I do?
Nothing, in most cases. Read through this FAQ for further explanations.
The first thing to know is: THE PBL IS NOT A BLACKLIST. You are not listed for spamming or for anything you have done. The PBL is simply a list of all of the world's dynamic IP space, i.e: IP ranges normally assigned to ISP broadband customers (DSL, DHCP, PPP, cable, dialup). It is perfectly normal for dynamic IP addresses to be listed on the PBL. In fact all dynamic IP addresses in the world should be on the PBL. Even static IPs which do not send mail should be listed in the PBL.
PBL listings do not prevent you sending email unless your email program is not authenticating properly when it connects to your ISP or to your company's mail server. This can happen if you have forgotten to turn on 'SMTP Authentication' or if you have switched 'SMTP Authentication' off by mistake.
If you are using a normal email program such as Outlook, Entourage, Thunderbird or Apple Mail and you are being blocked by a Spamhaus PBL listing when you try to send email, the reason is simply that YOU NEED TO TURN ON 'SMTP AUTHENTICATION' in your email program's account settings. That will solve the problem for you. See: How do I turn on SMTP Authentication?
Server admins who need help with SMTP AUTH can find lots of information for most servers such as Sendmail, Postfix, Exim, Qmail, Exchange, etc.
dick:quote
25-06-2015 3:12 PM
If you've been banned from a site, you should attempt to contact the site administrator and ask if they will unban you.
25-06-2015 3:20 PM
dick:quote
25-06-2015 4:57 PM
Nobody should be able to make a worldwide ban on the basis of one website's policies. I suggest that you contact Spamhaus and request them to explain why you have a received a worldwide ban on the basis of one complaint!
York.
25-06-2015 5:04 PM
See my previous reply for what these are used for.
25-06-2015 5:18 PM
What the PBL is intended to be used for is detection of operations not normally associated with a dynamic IP. For example it is unusual to find a mail server on a dynamic IP. Mail originating from one is likely to be from a compromised PC, so probably spam. However posting in forums would normally be allowed.
Are you sure being on the PBL is the only reason for the ban?
25-06-2015 5:19 PM
25-06-2015 9:29 PM
