asus dsl-ac68-u help please
- asus dsl-ac68-u help please
29-10-2014 11:19 PM
Re: asus dsl-ac68-u help please
29-10-2014 11:27 PM
Quote try these settings
Stability Adjustment (VDSL): disabled
Tx Power Control (VDSL): disabled
Rx AGC GAIN Adjustment (VDSL): stable
UPBO - upstream power back off (VDSL): enabled
SRA (Seamless Rate Adaptation): enabled
Bitswap: disabled
VDSL Profile: 17a
Improved Impulse Noise Protection (G.998.4): enabled
Quote I see talk in another forum that it is the bitswap option that causes the instability. Turning this off stablises the line.
29-10-2014 11:36 PM
30-10-2014 8:43 AM
ct 30 06:51:01 WAN Connection: Ethernet link down.
Oct 30 06:51:01 stop_nat_rules: apply the redirect_rules!
Oct 30 06:51:32 WAN Connection: WAN was restored.
Oct 30 06:51:32 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
Oct 30 06:53:57 WAN Connection: Ethernet link down.
Oct 30 06:53:57 stop_nat_rules: apply the redirect_rules!
Oct 30 06:54:44 WAN Connection: WAN was restored.
Oct 30 06:54:44 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
Oct 30 06:56:19 WAN Connection: Ethernet link down.
Oct 30 06:56:19 stop_nat_rules: apply the redirect_rules!
Oct 30 06:56:46 WAN Connection: WAN was restored.
Oct 30 06:56:46 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
Oct 30 07:34:59 WAN Connection: Ethernet link down.
Oct 30 07:34:59 stop_nat_rules: apply the redirect_rules!
Oct 30 07:35:45 WAN Connection: WAN was restored.
Oct 30 07:35:45 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
Oct 30 08:02:21 WAN Connection: Ethernet link down.
Oct 30 08:02:21 stop_nat_rules: apply the redirect_rules!
Oct 30 08:02:56 WAN Connection: WAN was restored.
Oct 30 08:02:56 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
Oct 30 08:12:47 rc_service: httpd 562:notify_rc restart_DSLsendmail
Oct 30 08:29:49 rc_service: httpd 562
Please can someone help ?
30-10-2014 8:51 AM
If you do, report the line fault and get it fixed before trying the Asus again. If you don't then take it up with Asus.
Plusnet only officially support the router they supply (though they do try to help with others). They are unlikely to be able to report a line fault if you're not using the modem provided as part of the service.
30-10-2014 9:00 AM
You'll end up causing DLM to intervene if you have too many disconnects in a 24 hour period.
30-10-2014 9:06 AM
30-10-2014 9:17 AM
If im right you get a high amount of CRC error. by doing the above i have only had 5 CRC in 2 days of uptime
30-10-2014 11:33 AM
ct 30 11:07:25 kernel: br0: received packet on eth2 with own address as source address
Oct 30 11:30:36 WAN Connection: Ethernet link down.
Oct 30 11:30:36 stop_nat_rules: apply the redirect_rules!
Oct 30 11:31:12 WAN Connection: WAN was restored.
Oct 30 11:31:12 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
30-10-2014 12:39 PM
That thread has lots of people with problems and things try too
30-10-2014 5:24 PM
30-10-2014 5:39 PM
30-10-2014 10:32 PM
Yet this is an all-in-one device, so the WAN isn't an Ethernet link... At least not one that exists outside the box.
The OP observed that the fault didn't cause a resync, just the loss of the PPP session. If true, it would seem strange that a config shift between 17a and 30a would solve the problem; if the modem portion thought there was a problem related to the 17a profile vs 30a profile, then it would surely resync!
Sounds like the Asus isn't quite ready for the primetime...
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
06-12-2014 2:09 PM
07-12-2014 12:19 PM
