any update on this ticket 141529547
scottymc
Hi any staff about that can see if there has been any movement on my fault
Thank you
Scott
58 REPLIES 58
Anoush
Aspiring Hero
Fixes: 139
Re: any update on this ticket 141529547
Just testing your line, I can see that your downstream speed is within estimates, the upstream is actually below the estimate.
Sync Status In Sync
Downstream Speed 62.1 Mbps
Upstream Speed 7.5 Mbps
An engineer was assigned last Tuesday the 10th, and couldn't find a fault. From your other thread, seems that you're getting a download speed of around 40 Mbps?
Are you using a wired or wireless connection?
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
scottymc
Download speed is creeping back up to normal but its still 6meg light....
Upload is 13meg light
Only run the the bt test and that was wired....
Mondays bt test and todays are below
Before the disconnection on Monday we were get solid 68meg/20meg ....
So I think there is a problem and your CS team said there was it showed up on their system....
Plus the grim upload shows something is up ?Huh
Thanks for your help so far..
Anoush
Aspiring Hero
Fixes: 139
Happy to hear the speeds are getting back up. The adviser that raised the fault on Monday didn't leave any notes for our faults team to explain what the issue is.
I'm just going to add some notes to the ticket now, I imagine it'll be picked up either today or early next week.
scottymc
Thank you buddy
Anoush
Aspiring Hero
Fixes: 139
No probs, if you don't get an update by the end of Monday feel free to let me know and I'll get it chased up.
scottymc
Hi
There has been no improvement on my sync speeds
Checked @ 3:30 today .....ill check again at 18:00
Thank you
Anoush
Aspiring Hero
Fixes: 139
Looking through your account I can see that our faults team have picked up your ticket a couple of hours ago. It's still being worked at the moment. I expect you to receive an update later today.
scottymc
Thank you buddy
scottymc
Still no change download stuck @60 upload @6.7
scottymc
Was there any update last night
Thank you
scottymc
Take it no news is...... No news....
Still no improvement
scottymc
Just read your email I will do as asked and post up the results in ten minutes or so but the sync speed on the up load side is still 13 meg low and the download has lost 8meg since the disconnection last friday ....
Look at the sync speed for the last 13 months and now look at it clearly there is a problem.... Bt test to follow
scottymc
Anoush
Aspiring Hero
Fixes: 139
Apologies for the lack of response, I wasn't in work today.
I'll check things out tomorrow.
