ag gateway speed drop
- ag gateway speed drop
25-07-2015 11:05 AM
on bng gateway I normally get 38/39 download but as soon as the gateway changes to ag the speed drops.
the worse so far was ptw-ag02 which dropped 8mb to 30 and as soon as it changed to pcl-bng01 the speed went back to normal.
now on ptn-ag04 and speed down to 36.
is there a problem with ag gateways?
Message 1 of 3
(486 Views)
2 REPLIES 2
Re: ag gateway speed drop
25-07-2015 11:19 AM
Message 2 of 3
(325 Views)
25-07-2015 11:28 AM
On ptw-ag02 and fine here too
Remember when you change gateway (or rather disconnect/reconnect to the router), you will also get a new end point which may have more of an impact than the gateway.
Message 3 of 3
(325 Views)
