Zyxel VMG 1312-B modem
- Zyxel VMG 1312-B modem
16-01-2016 5:01 PM
Hi
My current FTTC setup is an Archer TP-Link C9 router connected to a Zyxel VMG1312-B acting as the fibre modem.
The Zyxel is in bridge mode and connects to the WAN port on the C9. Everything else connects to the C9.
Everything works great.
The problem is that I want to log into the Zyxel and use DSL stats to monitor the line; however I can't log in.
If I try to go to 192.168.1.1 I get a connection timed out message; DSLstats cannot log in either.
Even if I connect a computer direct to a LAN port on the Zyxel I get nothing. Don't know a lot about subnets etc. so not changed anything on the Zycel or C9 (except 802.1q=101 to get it working)
Thanks in advance.
Thanks in advance.
Message 1 of 6
(3,140 Views)
5 REPLIES 5
Re: Zyxel VMG 1312-B modem
16-01-2016 5:28 PM
Well you won't be able to access the Zyxel when connected to the tp-link router, that's for sure.
You MAY be able to access it when connected directly to one of it's LAN ports, but my guess is that in bridge mode it's DHCP server is disabled. You would therefore need to set a static IP on the PC , I suggest 192.168.1.2 with a subnet mask of 255.255.255.0 and default gateway 192.168.1.1 . Don't forget to put the PC back to DHCP when you disconnect from the Zyxel.
Message 2 of 6
(2,341 Views)
16-01-2016 5:31 PM
Or
Leave the zyxel on 192.168.1.1 if you plan on using any of the stat programmes & place the tplink on 192.168.1.254
Kitz site ( - Even though we don't always agree on somethings :)) ) may of help.
http://www.kitz.co.uk/routers/zyxel_VMG8324-B10A_bridge.htm
Trailed the 1312 over on aaisp so if you want to go deeper in check out aa's wiki...
https://support.aa.net.uk/VMG1312:_CLI
Message 3 of 6
(2,341 Views)
16-01-2016 5:44 PM
Grrr double post...feel free to delete....its the shock of linking out the kitz obviously :)))
Message 4 of 6
(2,341 Views)
16-01-2016 5:46 PM
Quote from: Webif Kitz site ( - Even though we don't always agree on somethings :)) ) may of help rather than me going off on cli.
Thanks that looks exactly what I needed. Have to give it a go tomorrow now as the Chinese needs to be ordered!
Quote from: Webif Trailed the 1312 over on aaisp so if you want to go deeper in check out aa's wiki...
Yes seen that one - that helped me with the 802.1q problem.
Thanks ever so much - I'll report back tomorrow.
Message 5 of 6
(2,341 Views)
23-01-2016 5:04 PM
The Kitz solution worked perfectly. Now got DSLstats running 24/7 on the HTPC. Thanks.
Message 6 of 6
(2,341 Views)
