Youtube Issue
nigel1971
Youtube Issue
I'm having an issue and although sometimes it can be other sites not loading properly but youtube i find the culprit on a lot of occasions. I can load the site up pretty quick but clicking a video it takes ages to load and play with the cog wheel in the middle going round for ages til the video plays.
Is there a way to get this to improve quick video load times?
Internet speedtest is showing ok, ping times low at 11ms, down and uploads ok but just loading times the issue of certain things.
7 REPLIES 7
K50
Re: Youtube Issue
Have you tried clearing your cache files?
adamwalker
Fixes: 221
Re: Youtube Issue
Checks on your connection from here aren't revealing any problems.
Can you tell us what speeds you are seeing at present?
 Adam Walker
nigel1971
Re: Youtube Issue
Speeds as of now:
73.8mb down
18.8 mb up
Ping 11ms
Speeds look fine on that but loading videos on youtube take a while and not pretty much instant.
Pettitto
Fixes: 5
Re: Youtube Issue
Did you try clearing your browser cache?
It might be worthwhile clearing out any temporary files as well. Microsoft have a pretty decent guide around this: http://windows.microsoft.com/en-gb/windows/delete-files-using-disk-cleanup#delete-files-using-disk-c...
khile
Re: Youtube Issue
i too experience this on many occasions and can be any time thou out the day
ive tried clearing cache, restarting router and running a deep malware scan to make sure nothing was hijacking connection.
ive also experienced slow issues on Facebook and gmail
Re: Youtube Issue
 Well for what is may or may not be worth I was having issues with my internal LAN with my Mac dropping its connection, most noticeable on streaming site, like youtube, I did think at one point it may have been the TP-Link PowerLine Adapter I was using so I ran an ethernet cable to the cabinet, but this didn't work as I'd hoped.
I then looked at the configuration of the switch and noticed that the flow control and duplex weren't set correctly (after a previous system reset) so I changed the Duplex and Flow control back to auto and I've not had an issue since. I know you may not have a managed switch but it might be worthwhile checking these parameters on your network card.
Get the properties of your network card on screen and there you will see a Configure button click the Advanced tab and from the property list look for ‘Flow Control’ set this to Rx & Tx Enabled, then look for ‘Link Speed & Duplex’ and set this to Auto Negotiation’, click OK to apply these changes.
For my card you'll see the Flow Control highlighted and six entries below that you'll see the 'Link Speed & Duplex'
Re: Youtube Issue
@nigel1971 - Did you try this and or has your issue been resolved?
