Yet another PS customer with very slow fibre speed
- Re: Yet another PS customer with very slow fibre s...
31-01-2016 3:38 PM
Re: Yet another PS customer with very slow fibre speed
31-01-2016 3:55 PM
To be is to do - Kant
do be do be do - Sinatra
31-01-2016 4:05 PM
Please post the results of a BT speed test as asked for here http://community.plus.net/forum/index.php/topic,143836.0.html (the full version)
31-01-2016 4:07 PM
If I were you I would
a) report a speed fault via the troublshooter here : http://www.plus.net/support/broadband/bbfaults/fibre-speed-troubleshooting.shtml
If possible carry out all the steps requried of you.
b) next step is to give tech support a call: It has been quicker and easier to get a response recently & you may not have to wait a long time. Profiles can get stuck and it soemtimes needs a call to support to fix things.
31-01-2016 4:11 PM
31-01-2016 4:24 PM
Test 1 3.88 download 0.36 upload ping 42.88
Test 2 3.76 download 0.36 upload ping 39.00
Test 3 3.93 download 0.35 upload ping 42.88
Other speedtest taken:
29/01/16 10 yr old Plusnet thomson router non fibre no Cat5 cable and connected into BT extension socket (not Master) 2.99 download 0.36 upload.
31/01/16 New Hub1 router connected into master socket using Cat 5 cable and connected directly to laptop via ethernet cable 3.38 download 0.35 upload
31-01-2016 4:34 PM
31-01-2016 4:34 PM
31-01-2016 4:54 PM
You need to be able to test with only fibre modem plugged into the master and all other extn wiring disabled.
31-01-2016 6:15 PM
My master BT socket is a NTE5 as install originally by BT, Whilst testing speeds all other devices (2 telephones) were disconnected along with filters. No other computers etc being used, switched off.
31-01-2016 6:35 PM
- IP Profile : Also known as: BRAS profile
This a speed limit applied by equipment in your telephone exchange.
The IP Profile is designed to stop us from sending more data down your phone line than it (or your router) can physically handle. As such, it represents the maximum speed you can achieve whilst also receiving a stable connection.
The way an IP Profile is calculated depends on the broadband product
To find yours look up this page on the PN Portal and see what it says : (you will need to log into your account) https://portal.plus.net/my.html?action=stable_rate
It shows what info PN are getting from the exchange about your connection status and if youtr IP profile setting is wrong it will be clear from the data you see .
Here is mine for example:
Telephone number:
01xxxx xxxxxxxxxxxxxxxxx
Phone exchange:
TOY TOWN
Estimated line speed:
10Mb (This may vary between 5.1Mb and 10Mb) - Checked on 2016-01-03 13:20:02
Current line speed:
11.9 Mb
if you suspect things are not right you should report a speed or conenction fault . A stuck IP profile can often be fixed by the PN tech staff but they will need to speak to you and give you ceratin instrutions over the phone while you are at home. If its another issue then you may need an engineer to check the condition of the line .
31-01-2016 6:40 PM
Also you need to elimiate the possibility of mains current leakage into the phone circuit from other equiment like answerphones , cordless phones and Skyboxes etc etc
31-01-2016 6:42 PM
Just click on this http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do
Quote from: Juliaridge where would I find this IP details?
Note that the above poster is confused between the BT IP profile - which is what we need - and the Plusnet "Current Line Speed" which we don't need at this stage
31-01-2016 6:59 PM
Quote Just click on this http://www.speedtest.btwh...ceTesterWS/diagnostics.do
You are dead right fo course Oldjim : but shouldn't they be about the same? My BT IP profle was stuck this week and PN were able to identify the cause and fix it. The results from both were idecntical before the fix and after the fix had been appled both showed the same improved result .
Another suggestion is to look up https://www.dslchecker.bt.com to see what the theoretcical available service is on the line
31-01-2016 7:01 PM
Broadband product Unlimited Fibre
Estimated speed 19Mbps to 21MbpsThis estimate is based on data provided by our supplier. Your actual speed will vary but should be within the estimated range - find out why your speed can vary
This is a further email from Plusnet having connect new router:
High-speed Broadband
Telephone number:01752 xxxxxx Phone exchange:CROWNHILL Estimated line speed:74Mb (This may vary between 54.6Mb and 74Mb) - Checked on 2016-01-29 15:18:27 Current line speed:3.6 Mb Your estimated line speedIf we've done a line check for you, we provide an estimate of the broadband speed that your line should support. Please see above for the 'Estimate line speed'. We have also included a speed range, as the speed of your service can vary due to the nature of broadband. If we're unable to provide a line check, we give you the option of continuing without a speed estimate, in which case you'd see the Speed Estimate as "Opted out".What does "Current line speed" mean?The speed shown above is based on your sync speed. This is always a little higher than the speed at which data will actually be downloaded over your broadband connection. Find out more about sync speed.Learn more about why broadband speeds vary - high-speed broadband guide.
Hope this helps.
