Xbox Lag
- Re: Xbox Lag
Xbox Lag
03-07-2020 4:57 PM
I was wondering if anyone knows if there are any router changes that can be made to help with xbox lag.
We have 70Mb broadband and it seems to run fine on speed tests.
Both xbox ones are having the same problem, both are wired in, so wireless has been ruled out.
Tried to speak to plusnet via online chat but that doesnt seem to work anymore, also cant find a way to open a case.
So thought I would try the forum.
Any advice?
Thanks in advance.
Re: Xbox Lag
03-07-2020 7:24 PM
Thread moved from ADSL Broadband to Fibre Broadband.
Forum Moderator and Customer
