Would I benefit from Fibre Extra
spudy12
Can anyone from PN tell me if I would benefit from upgrading to the Fibre Unlimited Extra package? Smiley
7 REPLIES 7
Shep41
Seasoned Pro
Fixes: 6
Re: Would I benefit from Fibre Extra
The batteries have died in my crystal ball 😂😂😂 Maybe it would help if you tell us what package your on at the moment.
What does it say when you enter your phone number here
https://www.dslchecker.bt.com
Mav
Fixes: 515
What results do you get from entering your phone number in the DSL Checker?
Forum Moderator and Customer
Fixes: 1,600
Thanks for getting in touch.
As your speed estimates show a high value of 45mbps it's unlikely you'll see a great amount of improvement by upgrading to Unlimited Fibre Extra.
However, our tests are showing your router in sync at 27mbps which is below the low value of 32mbps so I'd recommend looking at some troubleshooting here then progressing this as a fault here so we can further investigate.
spudy12
Thanks for the information!
Sorry I am currently on Fibre Unlimited but assumed plus net would know that Wink
Would upgrading to the fibre extra increase me upload speed at all? Currently get around 4mb
Will give the troubleshooting tips a try and raise a fault if it doesn't improve.
Also BT have been installing new boxes down the end of my street, is there anywhere to find out what they are for>?
Fixes: 1,600
I'm not finding your account now via the usual means, but if you put your landline phone number into the BT checker at www.dslchecker.bt.com what are your upstream estimates?
You could try raising a query with Openreach here.
spudy12
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 45.4 32.4 7.9 5.2 30 Available -- --
VDSL Range B (Impacted) 40 25 7.4 4 20 Available -- --
This is the result. How do I know if I am classed as Clean or Impacted?
Distance wise I am roughly 500 meters from the green cabinet
Fixes: 1,600
Cheers for that. We'd go by the clean rating.
From those estimates, upgrading to fibre extra may improve your upload speeds slightly.
