Wireless light is flashing orange.
- Re: Wireless light is flashing orange.
20-05-2018 1:24 PM
20-05-2018 1:30 PM
Assuming you have a PN Hub One Router, have you tried re entering user name + password as on 'plate'
on Router, provided with this detail on?
Are you certain your BB has been activated/ had an e mail from PN confirming.
20-05-2018 1:36 PM
20-05-2018 1:46 PM
20-05-2018 2:03 PM - edited 20-05-2018 2:04 PM
Welcome to the forum.
Can we start from scratch, which light(s) precisely are on and what colour? See here:https://www.plus.net/help/broadband/router-setup-guides/ then go to the section 'If you can't connect, check the lights on your hub' section. If the Power light (in the middle on the front of the Hub One) is not showing blue then you're not connected to the internet. An orange flashing wireless light indicates that the WPS button has been pressed.
Are you using wireless or are you connected to the router via an Ethernet cable?
20-05-2018 2:11 PM
20-05-2018 2:21 PM
Push a pin into the back of your hub and try a factory reset.
While its resetting, login here: https://www.plus.net/index_nlp.html
Whatever username and password lets you login there, is your broadband username and password.
Once your router is reset, make sure in your router settings (http://192.168.1.254) you go to Advanced Settings > Broadband and your details are;
Broadband Username: yourusername@plusdsl.net
Password: the password that lets you onto the member centre.
Hopefully this fixes the issue, if not you may have to speak to technical support again.
20-05-2018 2:31 PM
20-05-2018 2:41 PM
Don't worry about the 'not secure' message. It's a generic message that doesn't know that your password is not being transmitted to the outside world.
What can happen is that either Openreach failed to connect you due to a last minute non availability of an engineer to make the connection. When this happens Plusnet are notoriously bad at advising the customer. Also it's possible that Plusnet haven't properly activated your account.
You need to contact them either by phone or using live chat. Note that live chat will not work if you use a pop up blocker. These are frequently automatically switched on in some browsers so you may need to go into the browser settings and temporarily disable it.
20-05-2018 2:55 PM
21-05-2018 12:00 AM
Either there's a set up problem-check the cables etc and that you're correctly filtered (no filter in a double socket). If all good call support for a line test (unless one of the staff here can run this)-could be a line issue, bad or failed install etc especially if the phone line has any issues or even a faulty router.
25-05-2018 2:49 PM
