Wireless Router Spec
- Wireless Router Spec
17-03-2016 5:52 PM
Can anyone tell me if the wireless router supplied supports N ? If not, am I able to just buy my own wireless router and connect that up rather than using the Plusnet one ?
Message 1 of 2
(609 Views)
1 REPLY 1
Re: Wireless Router Spec
17-03-2016 6:59 PM
You can use any VDSL modem/router you wish with Plus Net FTTC There is no restriction.
Which router do you have at moment?
go here to find out the spec of any Plus Net supplied device
http://portal.plus.net/support/broadband/hardware/
Message 2 of 2
(443 Views)
