Wireless Issue
- Wireless Issue
- « Previous
- 1
- 2
- Next »
Re: Wireless Issue
06-01-2015 6:28 PM
Re: Wireless Issue
06-01-2015 7:10 PM
Re: Wireless Issue
06-01-2015 7:26 PM
Anyone here know any of the answers?
Hello,
The wifi connections from the supplied Technicolor TG582n router is poor at best. The modem being used is a BT Openreach unit that was supplied by Sky when I was with them.
Can I change the Router and or Modem and will PlusNet offer support, also do you have any recommendations I was thinking of a Dual Band unit?
Re: Wireless Issue
06-01-2015 7:33 PM
Re: Wireless Issue
06-01-2015 7:39 PM
Also would the populus recommend a dual band router?
Re: Wireless Issue
06-01-2015 8:37 PM
I have also loaded on the Merlin-Fork firmware and have increased the output power of the wifi, now wifi it awesome anywhere in the house and outside.
Re: Wireless Issue
07-01-2015 3:31 PM
In hindsight I'd have been better off staying with Sky, as I now have to spend money to get a signal that was as good as the sky one was in the first place.
Not at all impressed!!
Re: Wireless Issue
07-01-2015 4:12 PM
Re: Wireless Issue
07-01-2015 4:19 PM
Re: Wireless Issue
07-01-2015 4:34 PM
I made mine for less than a fiver with the following tutorial from here... http://www.dd-wrt.com/wiki/index.php/Wireless_Access_Point
And a router from here http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.XD-link+dir-615+r...
Try getting Revision D3 or D4. You can even buy a DIR-615 with DD-WRT installed, just plug it in connect and change the wifi password, job done.
We have this conversation at lest once a week or so, the provided router is free (£5 Delivery) to keep costs down, and also to put in line should you have a problem and need support etc.
Or buy a decent router that will do what you need it to.
I feel your frustration as do others, that is why we are trying to help you, most people seem to get along with the supplied router but some don't, wether it be an OS issue or even drivers that can cause problems with wifi, who knows.
You say you have full signal, have you tried using plusnet dns settings on just 1 pc to see if it helps at all ?
How to change dns settings on windows
http://windows.microsoft.com/en-gb/windows/change-tcp-ip-settings
212.159.6.9
212.159.6.10
Just tick ( use the following DNS server address) then enter the above 2 addresss. shown in the pic below then save
Just untick then save to go back to normal.
Re: Wireless Issue
07-01-2015 4:56 PM
Thanks again
Re: Wireless Issue
09-01-2015 5:10 PM
I also left sky for plusnet and found the speed better but the bandwidth poo.
last night I plugged my sky router back in and so far so good! seems much better (Hubs can play the xbox whilst I watch crappy TV on catch up! woohoo!) I am also a plug and player but I did sign into the sky router and made one change on a setting, can't remember what but can check if you like?
good luck!
Re: Wireless Issue
09-01-2015 5:26 PM
Re: Wireless Issue
03-10-2016 12:36 PM
- « Previous
- 1
- 2
- Next »
