Windows 10 Pre-downloading
- Windows 10 Pre-downloading
Re: Windows 10 Pre-downloading
29-07-2015 12:39 PM
As always, excellent support from Sony. I'm in no hurry to ugrade as I'm more than content with W8.1.
29-07-2015 12:55 PM
Both 10240. One is Pro, the other Home.
Quote from: HPsauce The W10 test system is just sitting on the last fast version with no indications of anything; I'll compare its version to the laptop when that has upgraded.
The updated laptop is now installing some updates. Probably the same ones the test system already picked up.
My laptop was "semi-preloaded", when I started the process it said it was about 50% downloaded in Windows Update then carried on.
29-07-2015 2:07 PM
Quote from: HPsauce Interestingly I have 4 PC's eligible for this. Well five if you include a W10 test system.
Of these one (the one I'm using right now) has never shown any eligibility despite being W7x64 and apparently totally eligible - but a clean install is scheduled for the autumn anyway.
Apparently if Microsoft thinks that your machine will have issues with the upgrade, they have hidden the Windows 10 task bar icon until after the 29th of July and then will re-able it so you can see the issues that they think you will have. I have a laptop which will not show the icon but it meets all the criteria to be offered Windows 10. ( pukka license, Windows 7 SP1, all hotfixes and optional installs done)
Also I have just rebooted my desktop machine and the Windows 10 task bar icon has gone. It was there this morning as I click on it to see if it was saying anything different. The GWX.EXE isn't running too. However if you open Windows Update, it says that Windows 10 is coming soon and click to reserve a copy.
29-07-2015 10:41 PM
Quote from: Pendragon Yes it could that is one reason I posted this note.
The odd thing is I only found this out because at one point I had a small ‘cog wheel’ icon at the top right of the small window that opens when you click the icon on the task bar.
Clicking this ‘cog wheel’ gave a menu of things you could set including ‘get updates from the internet and local network’ and ‘updates from local network only’, however this ‘settings’ icon has vanished on all the windows I’ve opened today.
Microsoft may have changed this behaviour because of upload costs to the end user, I don’t really know. If anyone else has any input feel free to chip in.
Regards, P.
In the update - advanced settings there is a choice to disable people leeching off you.
30-07-2015 10:34 AM
Tracked this down to a problemwith failed install of 8.1
Can't upgrade to 8.1 as apparently the account I'm doesn't have administrator providelges. ( it does)
So what's the problem? If anyone can give me a pointer I'd be grateful!
Graham
30-07-2015 11:06 AM
You may need to enable the administrator account in Computer Management / Local Users and Groups first.
30-07-2015 11:12 AM
http://www.nextofwindows.com/windows-8-1-tip-how-to-enable-and-disable-hidden-administrator-account
30-07-2015 12:10 PM
30-07-2015 2:32 PM
Hmmm, first impressions, well I’ve been an ‘insider’ for a few months so was already sort of ‘up to speed’ with 10 (or so I thought), however upgrading is nothing like the lovely clean installs I did with the previews.
My laptop even though it upgraded fine is having problems shutting down, sometimes it will shut down fine others it will hang and I have to kill it with the power button. Otherwise everything seems to be working.
Games seems OK, office 2007 works as normal, but and this is the crunch bit, the start menu is taking a bit of getting used to. On Windows 8.1 I always installed Classic Menu and that worked fine, have yet to try it with 10 but may give it a go after a clean install, (you have to do the upgrade first as this registers your system with Microsoft (it uses your account) and then 10 will activate all on its own after a clean install.
Everything opening like ‘apps’ even on the desktop looks odd at first and the windows look a bit ‘insipid’ as in lacking colour and stuff and icons seem a bit ‘simplistic’, I must say I miss Aero even if it was a resource hog. But all in all it is a better operating system than 8.0 and only just better than 8.1, I think it will grow on me but it will take time to convert me from 7 for gaming.
As gamers we also have a backup Windows 8.1 games tower and a ‘gash’ tower with Windows 7 installed we use for testing stuff (our 2 main games machines are high end go faster machines and never, never get upgraded without tests on the backup first).
So first test on the Windows 7 machine, fully licensed and activated with SP1 etc, unable to update this machine because it is not activated (what?).
Downloaded the 10 iso and tried using that, it went through the entire installing etc and ended with the same message, then did a roll back and wiped all the downloaded files as well, thanks Microsoft.
Tried again last night with the ‘Media Creation Tool’ from Microsoft and it downloaded another 6 Gig (sorry Plusnet), did the install and says it can’t activate 10 as I have an illegal copy of Windows 7.
Well I have the box with a family pack of 3 licences purchased for my local PC World store and it was activated before the 10 upgrade started screwing things up.
Don’t think I will be upgrading my games machines just yet; more testing is in store over the next few days.
Daft part is I installed the final preview on my Asus Transformer T100 and that works like a dream both in desktop and tablet modes, but it was a clean install.
Just something you may or may not be aware of, if you click the ‘Notification’ icon in the task bar it will open a ‘slide up’ menu and you can use this to turn your desktop into tablet mode (if you wish though I wouldn’t know why LOL).
Regards, P.
PS to mods, you might like to move this to the Windows Software section, thanks.
30-07-2015 2:38 PM
I'm just getting use to where everything is and the interface it's a a little different to Windows 7 , I run the tool again to pick the create and burn ISO option so can do a clean install if needs be at a later date so far so good, one thing i'm not liking is Auto update being set to automatic with no means to change it, in Win 7 i always had it set to notify me and then i chose whether to download or not, Hopefully MS will patch that option back in, if not i'll see how it goes and go back to Win 7 if needs be.
30-07-2015 2:49 PM
Just hoping that Win10 does it for me. I won't rush and chase my download though, I'm not always the best when it comes to change, bit of a stick-in-the-mud! ^-)
30-07-2015 3:54 PM
I am guessing something on my rig is hanging the app
I downloaded the iso about 15 mins ago.
However I dont want to upgrade to win10 yet, so I would be concerned if this is a fully automated process without end user approval.
laptop also has exact same problem.
30-07-2015 4:51 PM
Quote from: Pendragon the start menu is taking a bit of getting used to. On Windows 8.1 I always installed Classic Menu and that worked fine, have yet to try it with 10 but may give it a go after a clean install.
Start8 start menu is working ok in win10.
Not sure I like the new win10 menu.
30-07-2015 5:24 PM
Quote Start8 start menu is working ok in win10.
That's excellent news, thanks for the update npr.
30-07-2015 6:40 PM
Win10 Menu
So nice to go back to the old start8 menu.
Start8 Menu in Win10
Edit:
Just discovered with Start8 enabled, the windows key brings up the win10 start menu.
Best of both worlds.
