Will there be new firmware for Sagem router F2704N?
- Will there be new firmware for Sagem router F2704N...
13-11-2015 1:28 PM
Re: Will there be new firmware for Sagem router F2704N?
14-12-2015 9:28 AM
14-12-2015 9:35 AM
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
14-12-2015 8:34 PM
Quote from: DTEG not worth the plastic it's cased in.
Not an unfair description. Cut your losses and replace it.
14-12-2015 9:12 PM
21-12-2015 8:27 PM
Quote from: ejs The initial firmware version for the Plusnet 2704N router was 7.273.1. There has been one newer firmware release, version 7.275.2. I can't remember what issue(s) it was supposed to fix, it sounds like there are still plenty of bugs needing fixing.
That's interesting. Not seen any notification of any upgrade, and reporting 7.273.1_F2704N_Plusnet.
21-12-2015 8:31 PM
Quote from: dvorak The default modem / router is now a Hub One, which is a rebadged HomeHub 5
Do you know if that's proving solid?
Is it worth pestering customer services for a free upgrade given that the F2704N is obviously not fit for purpose?
21-12-2015 8:36 PM
05-01-2016 8:19 AM
David
08-02-2016 9:13 AM
