Will my poor speeds make a difference?
baward
We have a pretty measly 4.3Mbs download and 0.88Mbs upload speeds on average. We are on regular broadband (Plusnet Unlimited) at the moment; will upgrading to fibre make any difference to (i.e. improve) our speeds?
Many thanks.
7 REPLIES 7
MattyC
Champion
Fixes: 46
Re: Will my poor speeds make a difference?
Well I've attached your predicted speeds on fibre. It would be a significant difference to what you have now so I strongly recommend it Smiley
Matty
baward
Thank you very much.
Ben
adie:quote
baward
I had fibre installed this morning. The BT engineer showed me on his PDA the new speeds, about 10 times higher than our old speed (about 4.5DL/0.8UL). This evening, I see that the upload speed has risen considerably, but the download speed is the same. I wonder, when can I expect to see both speeds improve as expected?
Thanks.
That'll be because your Current Line Speed has not updated. If it hasn't automatically updated you can either wait for a Forum staff person to correct it for you, or give the help desk a call.
Fixes: 167
@baward
Everything is showing fine from this side now. Can you try logging in to your router and pressing disconnect, then connect.
 Chris Parr
 Plusnet Staff
baward
Thank you for the reply.
I realise I don't actually know how to log out of my router; I can switch off Wi-fi but that's not the same as logging out is it? I am on a Mac running Yosemite.
Ben
Fixes: 62
http://www.plus.net/support/broadband/hardware/ explains - just select your router
