Wifi speed
Paulpj
Wifi speed
Evening all, my WiFi has been slow 18-22mbps , tried speed test via Ethernet and it’s 44. What could it be please? I’m in the same room as router about 12 feet away
runhare
Re: Wifi speed
most likely cause is electrical interference, Christmas lights? might not even be yours! Could even be a christmas tree ( I am not kidding )
Other causes could be congested wifi channels. If you can do a wifi scan to find out which other wifis are broadcasting in your home . Maybe some other device is broadcasting on the same or an adhjacent channel.
Another common cause of interference are Wi fi Homeplugs which when a few years old can cause all kinds of problems .
Post your findings and other may suggest additional checks
Paulpj
Re: Wifi speed
Thanks for the advice, how do I carry out a WiFi scan please? Is there an app
Seasoned Champion
Fixes: 44
Re: Wifi speed
I use the Android app WiFi Analyser on my phone to monitor networks.
Are you using a Hub One? If so log into it and in the Advanced Settings you will find the option to separate the 2.4 and 5 GHz channels. Identify the 5GHz channel by adding something like -5 to the name. If your subject equipment is capable of 5GHz then rescan and select that. Good luck.
Fixes: 382
Re: Wifi speed
Hi there.
As well as the above suggestions, I'd recommend running through the troubleshooting here.
Let us know how it goes.
celica2012
Re: Wifi speed
Hi, I'm suffering the same slow WiFi speeds just wondering if you've found a fix for this?
