Wifi keeps dropping out
- Wifi keeps dropping out
03-03-2019 8:13 PM
Every so often my WiFi keeps dropping out and we can’t get any internet in your phones/tablets. This is so frustrating. Just wanted to know if there is any service update due to the high winds or if there’s a fault on the line?
Message 1 of 2
(242 Views)
1 REPLY 1
Re: Wifi keeps dropping out
04-03-2019 12:04 PM - edited 04-03-2019 12:05 PM
Hi @Niccithom,
I'm sorry to hear that you're experiencing connection problems.
I've tested your line but the test hasn't picked up any issues from here:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 51.4 Mbps | ||||
Upstream Speed | 8.2 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Estimated Line Length In Metres | 649.5 | ||||
Upstream Rate Assessment | Low | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | From 15:15 to 20:45 | ||||
Interference Location | Customer Premise | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-55M Downstream 6dB, Error Protection Off - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2019-02-19T12:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 50.0 Mbps | 50.6 Mbps | 50.5 Mbps |
Up Stream Line Rate | 8.6 Mbps | 8.8 Mbps | 8.8 Mbps |
Up Time | 859.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-03-04T11:30:39.253+00:00 | 2019-03-04T11:45:39.253+00:00 |
Ingress Code Violation | 0 | 9 |
Egress Code Violation | 0 | 1 |
Errored Seconds | 0 | 7 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
and the connection log shows a stable connection with one drop within the last ten days:
So that we can determine the best way towards resolving this, please can you confirm whether this is solely affecting wireless connections or if wired connections are affected too?
Message 2 of 2
(189 Views)
