Wifi Calling
Gavin
Wifi Calling
Hi
I've moved from TalkTalk to Plusnet.  No issues with wifi calling on the old provider, but can't get it to work with Plusnet.  I have tried different phones as well as turning off the router firewall.  I have a Hub One. Are there any changes I need to make?
Gav
Fixes: 33
Re: Wifi Calling
Who is your mobile service provider?
Have you connected them to your PN WiFi?
Gavin
Re: Wifi Calling
My mobile provider is actually Plusnet,
Fixes: 33
Re: Wifi Calling
Ah, well unfortunately PN Mobile does not support WiFi calling.
Lots have complained on here already.
Gavin
Re: Wifi Calling
Looks like I'll be looking for a new ISP as well as Mobile provider as neither can provide me with working mobile coverage.
Seasoned Champion
Fixes: 58
Re: Wifi Calling
It's not a problem with the fixed line ISP, I use Wifi calling on my Plusnet service with a mobile using the 3 network. It's the Plusnet mobile service that's your problem.
Gavin
Re: Wifi Calling
Both you and Plusnet seem to think that i should differentiate between mobile and broadband as two separate companies.  Which I do not find credible.  Especially when the support areas don't talk. This together with random drop-outs I get (mentioned by others in posts) means I will be looking for a better ISP asap.
(btw, EE who Plusnet get service from do support wifi calling)
Seasoned Champion
Fixes: 58
Re: Wifi Calling
@Gavin
In case you're not aware I am not a Plusnet employee, I am a customer the same as you. You might not think that it's credible to use two separate companies for mobile and fixed communications but many do.
The purpose of my post was to try and advise that you don't need to go through the hassle and potential cancellation costs of changing your ISP just because you don't like their add on mobile service but the choice is obviously yours.
