Wifi Calling
Gavin
Wifi Calling
Hi
I've moved from TalkTalk to Plusnet.  No issues with wifi calling on the old provider, but can't get it to work with Plusnet.  I have tried different phones as well as turning off the router firewall.  I have a Hub One. Are there any changes I need to make?
Gav
9 REPLIES 9
Mustrum
Fixes: 77
Re: Wifi Calling
Who is your mobile service provider?
Have you connected them to your PN WiFi?
Gavin
Re: Wifi Calling
My mobile provider is actually Plusnet,
Mustrum
Fixes: 77
Re: Wifi Calling
Ah, well unfortunately PN Mobile does not support WiFi calling.
Lots have complained on here already.
Gavin
Re: Wifi Calling
Looks like I'll be looking for a new ISP as well as Mobile provider as neither can provide me with working mobile coverage.
Fixes: 417
Re: Wifi Calling
It's not a problem with the fixed line ISP, I use Wifi calling on my Plusnet service with a mobile using the 3 network. It's the Plusnet mobile service that's your problem.
Gavin
Re: Wifi Calling
Both you and Plusnet seem to think that i should differentiate between mobile and broadband as two separate companies.  Which I do not find credible.  Especially when the support areas don't talk. This together with random drop-outs I get (mentioned by others in posts) means I will be looking for a better ISP asap.
(btw, EE who Plusnet get service from do support wifi calling)
Fixes: 417
Re: Wifi Calling
@Gavin
In case you're not aware I am not a Plusnet employee, I am a customer the same as you. You might not think that it's credible to use two separate companies for mobile and fixed communications but many do.
The purpose of my post was to try and advise that you don't need to go through the hassle and potential cancellation costs of changing your ISP just because you don't like their add on mobile service but the choice is obviously yours.
Shack
Re: Wifi Calling
I had exactly the same problem. I have been a Plusnet broadband customer for 14 years, and changed my mobile carrier to Plusnet in expectation of using the EE wifi calling facility, having very little cell coverage from any provider, only to find that the cheapskates don't provide it, although EE do. So I have swapped mobile carrier to IDmobile, which not only does provide wifi calling, but is also cheaper! I am also, after 14 years, shortly changing BB supplier to a better deal, as Plusnet, probably like most, do not reward loyalty.
southerner
Re: Wifi Calling
If I remember rightly EE only gave WiFi calling to contract phone & SIM Only customers & then it was only supported on certain phones running EE firmware. So not all even their own customers got it. & so unfortunately I wouldn't be too surprised Plusnet don't supply it being an EE MVNO.
