WiFi constantly dropping out
- WiFi constantly dropping out
- « Previous
- 1
- 2
- Next »
Re: WiFi constantly dropping out
02-04-2019 3:59 PM
It seems like some user have got them to do a software update to resolve issues. I didn't get the same response or outcome managed to c9nvince them to send a new router which also had the same issue from new. Had to buy a BT home hub 6 to resolve matter . All you need is user name and password for Plusnet to put into home hub for it to work . Second hand on eBay about £25 and a much better router no issues since installing what's so ever.
02-04-2019 4:39 PM
Is this the latest?
Just working through the replies
Thanks everyone for the help!
02-04-2019 4:50 PM
I’ve only just left bt and posted back the hh6 last week.
Wish I hadn’t
02-04-2019 4:51 PM
02-04-2019 5:09 PM
02-04-2019 5:45 PM
02-04-2019 6:22 PM
Thanks for the help
I’ve changed the stopped the wireless sync and renamed to 5g.
This already seems much better, no lag, WiFi seems just faster
In response to the wired connection part, the issue is just on my phone with the wireless, I usually run my Xbox with an Ethernet cable though this seems to get dropped frequently too, by this I mean it was showing the connection just disappeared and would have to connect to wireless.
Just reconnected it and it seems to work for now. I’m unsure weather this dropping of the wired connection is related. I thought it may have been my Ethernet cable with removable ends causing issues.
I haven’t tested the socket or any of the other introductory steps yet as everything was peachy until I swapped router
02-04-2019 6:31 PM
Swhen I try either network now they both seem to work, original and 5g one both work well!
Will report back in a few days if there is any issues
Is there a downside to running it like this at all?
02-04-2019 7:18 PM
02-04-2019 7:28 PM
02-04-2019 8:01 PM
@Kevinbell I can see you wrote this 09/02/19
Hi, I to have also been having the same issues for a few months now WiFi keeps disappearing and had to restart router several times. I did manage to convince Plusnet to send a new router which didn't resolve issues. I did notice this issues started to occur after connecting more devices. Spoke to support several times did many things to resolve nothing worked.
I know it's too late for you now, but the hub one running software version 259 could have been a possible reason why your router was how it was. I don't know. A software has been 'set free' ending in 263, which was supposed to overcome the issues 259 could have created.
At the time I would have been on firmware 259. But due to my own setup, I wouldn't have seen any issues on 5GHz. I am surprised to see you didn't get any support. Mine was only picked up as I posted a fair bit of evidence up (no, not judging you) and those images proved something was wrong.
I too went on to use a BTHub6, but at the request of Plusnet I have just swapped back to using their Hub One.
Regarding the other posts on this thread, it is hard to work out sometimes who has set their router to what. As I and some others for that matter appear to have issues on 263, it's easy to assume other posters are in the same boat.
Separating the 2.4GHz and 5GHz can help others out there too, but time will tell if the splitting has actually fixed their issues. I hope it does.
I tend to set my routers in a set way, here is how I set mine but many leave them set to it's default settings.
- « Previous
- 1
- 2
- Next »
