WiFi constantly dropping out
FIXED- Subscribe to RSS Feed
- Re: WiFi constantly dropping out
10-08-2019 10:15 PM
This is getting ridiculous now , even logging into this site I was on WiFi then it drops out and switches back to 4g on my iPhone . When ever people come over they log into my network and then it constantly drops in and out , so now most people don’t even bother to log into the WiFi network .
I have no problems with the PlayStation or desktop pc and my tado heating as they are all wired into router it’s just the WiFi , I am paying for a service that I can’t seem to use .
Can you check your end please
And also what can I do to resolve this problem
This affects all iPhones that are connected to the dual network
Fixed! Go to the fix.
10-08-2019 11:11 PM
You're not paying for WiFi, you're paying for the connection to the home.
10-08-2019 11:22 PM
10-08-2019 11:29 PM
The plusnet hub is notoriously bad when it comes to wireless. However, you don't pay plusnet for "WiFi", you pay them for access to the Internet via a wired device, as highlighted in their T&Cs.
11-08-2019 12:04 AM
11-08-2019 1:27 AM - edited 11-08-2019 1:38 AM
@Nordicgod1972 wrote:
was routing around the garage earlier and found the BT home hub , is it possible to install that instead ?
Assuming it's a Fibre compatible BT Home Hub, you should be able to use it.
I take it there might be a guide to it somewhere?
This Post should help with the setup
EDIT:
If you've got a Smarthub 6, it'll be This Post
12-08-2019 11:59 PM
Sorted followed guide and stuck the BT home hub 5 router back place of the very bad plus net one and all working well
13-08-2019 10:14 AM
We're really glad to hear you're up and running, @Nordicgod1972
If you require further assistance, please feel free to get back in touch as we are more than happy to help.
Kind Regards
15-11-2019 9:39 AM
15-11-2019 1:57 PM
Hi there Nixy,
Thanks for reaching out to us here.
I'm sorry to hear you are having trouble with the WiFi service, are you noticing this issue with any other device? Have you tried to connect via a ethernet cable & monitor for drops?
I have tested your service today, and your circuit is currently in sync at 27.2mbps which is below your estimates - can you go through our troubleshooting guide here and let us know how you get on?
Thanks.
15-11-2019 7:52 PM
16-11-2019 10:57 AM
Hi @nixy,
Thank you for confirming that you have been through the troubleshooting checks. I'm sorry to hear that this hasn't resolved the problem.
I've tested your line and the test isn't picking up any problems from here and shows that your line is still syncing at 27.2mbps. Contrary to what my colleague has said, this is within the estimates for the line which are 25- 39.3mbps. As this is the case, it appears that the issue lies with the wireless signal.
I've sent you a new router to try and it'll be with you within 3-5 working days. There's no charge for the router or the postage as you're within your contract. Please let us know if this issue persists once you have the new router.
17-11-2019 9:01 AM
09-12-2019 8:20 PM
10-12-2019 3:02 PM
Hi @nixy, thanks for your post.
We're sorry to hear that the issue has re-occurred.
I note from a previous post that on the old router you'd completed all of the troubleshooting - Did this include splitting the frequencies and if so have you been able to split the frequencies on the new router as yet, to see if it improves things?
