WiFi constantly dropping out
Nordicgod1972
Been with plusnet for 6 months now , before I was EE and never had a drop out and before that BT and also never had a drop out .
This is getting ridiculous now , even logging into this site I was on WiFi then it drops out and switches back to 4g on my iPhone . When ever people come over they log into my network and then it constantly drops in and out , so now most people don’t even bother to log into the WiFi network .
I have no problems with the PlayStation or desktop pc and my tado heating as they are all wired into router it’s just the WiFi , I am paying for a service that I can’t seem to use .
Can you check your end please
And also what can I do to resolve this problem
This affects all iPhones that are connected to the dual network
7 REPLIES 7
notmyname
Re: WiFi constantly dropping out
"I have no problems with the PlayStation or desktop pc and my tado heating as they are all wired into router it’s just the WiFi , I am paying for a service that I can’t seem to use ."
You're not paying for WiFi, you're paying for the connection to the home.
Nordicgod1972
I am paying for a service and it’s not working as advertised ,what’s a WiFi router with defective WiFi but thanks for your input , If you can’t help then why comment Huh?
notmyname
I can help if you wish, but you're not going to like the answer. You can either try changing the wireless channels on the router, or buy your own router.
The plusnet hub is notoriously bad when it comes to wireless. However, you don't pay plusnet for "WiFi", you pay them for access to the Internet via a wired device, as highlighted in their T&Cs.
Nordicgod1972
Ok will give that a go , was routing around the garage earlier and found the BT home hub , is it possible to install that instead ? I take it there might be a guide to it somewhere?
Fixes: 240
Assuming it's a Fibre compatible BT Home Hub, you should be able to use it.
This Post should help with the setup Smiley
EDIT:
If you've got a Smarthub 6, it'll be This Post
 Harry Beesley
 Plusnet Infrastructure Operations Professional
Nordicgod1972
Sorted followed guide and stuck the BT home hub 5 router back place of the very bad plus net one and all working well
Fixes: 29
We're really glad to hear you're up and running, @Nordicgod1972
If you require further assistance, please feel free to get back in touch as we are more than happy to help.
Kind Regards
 OllieC
