Why streaming is poor?
- Re: Why streaming is poor?
21-03-2015 10:10 PM
has anyone got a plausible answer as to why Blinkbox would start buffering when played through xbox 360 when I NEVER had a problem with any streaming from any site using ADSL.
IPad seems ok to stream, Netflix and Amazon in HD but can I get a decent picture through blinkbox on SD, NOPE!
Go on fibre everyone said, it's better they said, well so far I can't say my gaming experience has improved, lag and rubber banding even Europe only servers and streaming through consoles has definitely gone down in quality.
35/15 28 ping, get this pretty constant every time I do a speed test on Ookla.
Any thoughts or,answers?
Message 1 of 8
(1,429 Views)
7 REPLIES 7
22-03-2015 5:51 AM
I have had sporadic issues playing Netflix on the Apple TV - not too sure what the answer is.
Have you tried to delete the Blinkbox app and then re-download?
Rick.
Rick.
Fibre Broadband 80/20, Netgear D7000
Message 2 of 8
(685 Views)
23-03-2015 9:56 AM
With Netflix and Amazon working fine it seems very localised to Blinkbox. Removing and re-adding the app seems like a good first step. Are you connected via ethernet or wireless.
Message 3 of 8
(685 Views)
23-03-2015 1:12 PM
Chris,
I did a bit of googling and noticed that the Blinkbox app for xbox one had come out so tried that, which seemed to work fine, Sunday evening 6-8, peakish time?
Notwithstanding that I can't watch iplayer on the xbox 360 because of buffer, not that I have to but thats not the point, not everyone wants to or can get the next gen consoles just to stream their TV/films.
Is this a conflict with fibre and previous gen consoles, never had an issue on xbox 360/ps3 with ADSL2.
All consoles etc on wireless with approx 38/15 30 ping pretty consistently.
Message 4 of 8
(685 Views)
23-03-2015 2:12 PM
Sorry, I'm a bit confused now.
Has the situation changed since your first post? As in that you said that iPlayer etc were fine (through a tablet) but that it was only Blinkbox HD that was having issues.
Are you experiencing problems streaming anything now on your XBOX 360?
Message 5 of 8
(685 Views)
23-03-2015 3:20 PM
Chris,
Sorry, to clarify,
ipad streaming has seen no change from ADSL to Fibre
Since we changed to fibre there has been significant degradation of streaming quality when iplayer and Blinkbox were played through XBOX360 and ps3, SD quality.
We now have XBOX One which I recently downloaded the Blinkbox app for which worked buffer free last night on HD quality.
There is currently no Blinkbox app for PS4 so if I want to watch a film away from the kids I have to watch it on PS3 which buffers to the point that it is unwatchable.
So, my last thought/question was, do the last gen consoles suffer when using fibre for certain streaming sites as this could be a deal breaker for those people looking to change providers or those PN users moving from ADSL to fibre?
Sorry, to clarify,
Message 6 of 8
(685 Views)
23-03-2015 4:05 PM
I have XB1 and XB360 and they seem to work pretty similar. How old is the wireless adapter that you're using on your 360?
Message 7 of 8
(685 Views)
24-03-2015 7:44 AM
Matty,
Not sure, when we got it I just set it up, no need to add or plug in physical adapter's, unless its an internal thing and I need to look in a menu for example?
Message 8 of 8
(685 Views)
