Why not the Hub One when upgrading to fibre?
AdrianRoberts
I have just phoned to upgrade to fibre from ADSL and asked for the self-install option. In the confirmation email I see that I am being sent the 2704n router. I was expecting to get the Hub One router - I was really wanting ac, dual-band and gigabit ethernet porta.
Is there any reason why I haven't got the Hub One?
13 REPLIES 13
Darkfire
Fixes: 30
Re: Why not the Hub One when upgrading to fibre?
You should be getting a Hub One for upgrades and new connections, I'll get that updated and one sent to you
AdrianRoberts
Excellent; thanks for the quick response.
Will I get an email confirming this?
Mal08
I didn't get a Hub One when I upgraded - I got a Sagem one Huh
Darkfire
Fixes: 30
Hub One added to your account and ordered to be sent out, I've sent you an email with confirmation too Smiley
@Mal, you're on FTTP as far as I remember? with FTTP we are still supplying the 2704n at present
AdrianRoberts
Ta muchly
Cheesy
Mal08
Quote from: Darkfire
Yes I am - just wondered why ?
chenks76
All Star
Fixes: 12
so existing cusomers upgrading can now get a self install ?
HarryB
Fixes: 256
All FTTC orders should now be self install. However I've seen a couple of accounts where automation has placed normal FTTC orders with engineer appointments.
This has already been flagged up and we're investigating/working on a fix for this Wink
 Harry Beesley
stevegow
Hi Harry
I did an online upgrade to Fibre on Wednesday, had to pick an engineer visit.
text message said I'll be sent a Hub One.
mav:quote
AdrianRoberts
I've now received various emails and texts concerning routers. It looks like I am being sent both routers (or maybe more!). Unfortunately I can't reply to the emails, which is frustrating.
Assuming I get both, can I return the 2704n without cost?
Also, could someone please confirm I am on self-install?
Thanks for your help.
Darkfire
Fixes: 30
Hi again Adrian,
I only see the Hub One as sent out, if you receive another I can't find where that's been sent from but won't cause any issues, It seems the Fibre order wasn't picked up correctly though so I've just resubmitted it to BT Wholesale as a self-install
AdrianRoberts
Thanks Paul, again, for the swift reply.
The postman's just been and I've received both routers. The Hub One shows customer order 0-1971628 on the label and the 2704n shows 0-1971553 on the label.  I'll not open the latter: let me know what you would like me to do with it.
Any ideas on ETA, given the order problems?
Thanks,
Adrian.
Darkfire
Fixes: 30
Actually scratch that last comment, that Hub Zero was my error, I removed it from your account without sending a returns bag, leave it with me, I'll get a bag to you
I'll get you an exact connection date as soon as it's accepted, should be later today that I know Smiley
