Why is plusnet fibre rubbish
- Re: Why is plusnet fibre rubbish
19-01-2016 8:09 PM
I would like to know why plusnet is so behind the other providers the fibre is so slow can't get it in garden or in the back bedroom when I was with sky I got it everywhere even about I might just go back to sky
Message 1 of 9
(2,525 Views)
8 REPLIES 8
19-01-2016 8:15 PM
That will be down to router what router do you have the new hub one?
Message 2 of 9
(1,717 Views)
19-01-2016 8:21 PM
Did you follow up the reply you had two months ago?
http://community.plus.net/forum/index.php/topic,145785.msg1286117.html#msg1286117
Message 3 of 9
(1,717 Views)
20-01-2016 10:58 AM
To be fair I've had reasonable speeds from fibre until recently. the problem is that the PlusNet support team simply wont help - they just recycle the same old rhetoric instead of fixing faults.
But your problem isnt your fibre it's your wi-fi as it is location dependant. The standard PlusNet router is a bit pants and the wi-fi is awful on it. I also moved from sky (big regret) and their router had excellent Wi-Fi reception. Problem is - PlusNet tell you that if you buy your own router they wont offer support, well that's what they told me. I'm still thinking of buying a decent router though as everything else in my house is gigabit and the PlusNet router is only 100mb/s
Apparently there is a new plusnet router how which is a rebranded BT Home Hub. Might be better if you can get one though the only news about it I've read is that it is only available to new fibre customers.
Message 4 of 9
(1,717 Views)
20-01-2016 12:15 PM
Quote from: DJColinCook PlusNet tell you that if you buy your own router they wont offer support, well that's what they told me.
Plusnet would not offer direct support for a router they didn't supply but they do still support every other aspect of the service. As long as you keep the Plusnet router just in case you have a fault and need to plug it in for troubleshooting the support issue is no longer a problem.
Call me 'w23'
Message 5 of 9
(1,717 Views)
20-01-2016 2:34 PM
Exactly as above. Once it's working, what support do you need?
If there is a problem, go back to the Plusnet supplied kit if you need to call/diagnostics and there is no problem.
I've had my Asus working since I joined Plusnet and I've never needed support.
Message 6 of 9
(1,717 Views)
20-01-2016 2:53 PM
Also, this forum is usually a great source of unofficial support.
Call me 'w23'
Message 7 of 9
(1,717 Views)
20-01-2016 3:25 PM
As above, just buy a better router - problem solved.
You don't have to break the bank to do so, and pretty much anything will be better than what you have now. ISP-supplied routers are generally pretty lame.
Message 8 of 9
(1,717 Views)
20-01-2016 6:50 PM
or alternatively get a wireless extender, at about 30 quid money well spent.
I recently got the D-Link DAP 1520, works a treat.
Cheers
Cheers
Message 9 of 9
(1,717 Views)
