Why is my fibre download speed only 8mb and upload only 0.5mb?
rhambleton1
My fibre speeds are no better than adsl was. In fact they are a bit slower (see attached screenshot).
 Can anything be done about this, other people on my street have much higher speeds?
Browni
Aspiring Hero
Fixes: 46
Re: Why is my fibre download speed only 8mb and upload only 0.5mb?
When did you upgrade to fibre?
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
rhambleton1
Almost a year ago now, always been the same.
Browni
Aspiring Hero
Fixes: 46
If the line attention figure in your screenshot is for an existing fibre connection you must be a long way from the fibre cabinet which will obviously affect the line rate.
What does the DSLChecker show for your estimated speeds?
rhambleton1
It says 13mb is the maximum fibre speed for me on cabinet 5. However, my relatives further down the street are also on cabinet 5 which is even further away than I am and they get 27mb!
Fixes: 210
Sorry to hear your speeds are poor.
Our tests aren't showing any cause but your estimated distance from the cabinet is 2km which won't help things.
If you raise a fault here we'll see what we can do,
 Matthew Wheeler
rhambleton1
Thank you, I have now raised a fault.
