Why is interleaving turned on for my connection?
- Re: Why is interleaving turned on for my connectio...
21-07-2015 5:56 PM
Stats recorded 21 Jul 2015 17:51:32
DSLAM/MSAN type: BDCM:0xa44f / v0xa44f
Modem/router firmware: AnnexA version - A2pv6C038m.d24j
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 23 hours 2 min 43 sec
Resyncs: 0 (since 21 Jul 2015 17:48:58)
Downstream Upstream
Line attenuation (dB): 9.8 0.0
Signal attenuation (dB): Not monitored
Connection speed (kbps): 79360 19999
SNR margin (dB): 6.3 15.3
Power (dBm): 12.5 -5.2
Interleave depth: 8 1
INP: 48.00 0
G.INP: Enabled
RSCorr/RS (%): 0.0001 0.0597
RSUnCorr/RS (%): 0.0000 0.0000
ES/hour: 0 0
Re: Why is interleaving turned on for my connection?
21-07-2015 6:06 PM
21-07-2015 6:48 PM
With G.INP enabled. this will make your connection even better, as you will see less errors (ES/SES) but maintain the latency times of fastpath.
21-07-2015 6:50 PM
21-07-2015 7:03 PM
Think I better go back to studying up about G.INP in more detail. Sorry and cheers.
Still can't understand what's preventing me from synching at the 80/29 I had for months??? It's bugging me now. Wonder if there's a problem internally/master-socket?
21-07-2015 7:22 PM
[Moderator's note by Dick (Strat): Full quote of preceding post removed, as per Forum Rule]
21-07-2015 7:48 PM
Quote from: artfulbodger Thanks Matthew. I knew G.INP was turned on since April this year. But how is the line still showing interleaving of 8?
The 'interleaver depth' still applies when G.INP is enabled.
What's important is that the 'delay' is shown as being 0.
As for you not sync'ing at full rate, that could be down to many factors, crosstalk being one. Or the time of day when the resync occurred, what the weather conditions were like, or if interference was present.
21-07-2015 9:01 PM
21-07-2015 9:24 PM
Old-style DLM intervention would turn on very high levels of interleaving (not just higher depth, but higher block size, or "width") and FEC protection.
Under new-style "retransmission", G.INP is turned on, but both interleaving and FEC protection stay in use. However, the settings are much less aggresive: interleaving delay amounts to around 0.2ms instead of 8 or 16ms, and the FEC overhead amounts to around 5% of bandwidth instead of 20%.
Quote from: artfulbodger Still can't understand what's preventing me from synching at the 80/29 I had for months??? It's bugging me now.
Don't let it bug you, it isn't worth it.
VDSL2 is heavily susceptible to crosstalk - which is noise introduced by other FTTC subscribers. This means that your speed can drop whenever new subscribers are added, but the impact is highly random; In practice, you will lose speed in fits and bursts over a couple of years.
When BT Wholesale's DSL checker provides you a range of estimated speeds, they don't just mean that your speed will end up in that range on day 1 and you keep that speed forever more. What they mean is that your speed will vary within those limits over time.
Over 2 years, my line had attainable speeds that dropped from around 90/25 to 78/22. Whenever DLM intervened, that end speed would drop to 72/20.
Vectoring is the proper solution, if/when BT choose to deploy it.
Quote from: artfulbodger if I were to do a forced re-synch what time of the time would you recommend I do it? I've heard early mornings is best, unless it doesn't matter anymore.
If you want to be sure, it would be when your SNR levels are at your highest. Here that period can start anytime between midnight and 4am, and end between 7am and 10am.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
21-07-2015 9:52 PM
22-07-2015 12:55 PM
22-07-2015 5:02 PM
Once the modem is back in sync, you may have to log into your router and reconnect (or it may be automatic).
Good luck.
23-07-2015 12:57 AM
I had a day of power outages recently, with an RCCB playing up. I went through quite a few re-syncs (at least 5) before DLM intervened; then a few more re-syncs which caused it to get worse.
