Why has my speed been cut?
- Why has my speed been cut?
- « Previous
- Next »
Re: Why has my speed been cut?
13-05-2015 3:58 PM
Cheers, it's a touch better.
13-05-2015 5:36 PM
Quote from: buseng12 Ah, that explains it. My router just did another ppoe session on it's own accord before I read this.
What's your BT IP Profile now?
It appeared 'wrong' at 40.75 Mbps with your sync speed of 43,998 kbps.
I would have expected an IP Profile of 42.56 Mbps for a non-G.INP connection & 42.54 Mbps for your G.INP active connection (based upon every other connection's stats I have seen over a few years & G.INP active ones more recently).
13-05-2015 6:04 PM
Strange that there is only 0.75 leeway.
13-05-2015 6:11 PM
Quote from: buseng12 No, still 40.75. Also still just in the red.
There's something definitely wrong there then, but I have no idea what it could be.
IP Profile is based upon sync speed.
We have seen that when a new PPP session has been initiated, IP Profile is always around 96.79% of sync speed for non-G.INP connections & around 96.69% of sync speed for G.INP active connections.
13-05-2015 6:16 PM
20-05-2015 11:21 AM
My current sync rate is now 53999 kbps, however using the figure I have been given-96.69%- for G-INP enabled connections, my BT profile should be about 52212 kbps.
Running the test only gives it 49990 kbps though. Would this be due to the fact I am still on level 4 interleaving on downstream? Or is my line compromised in some other way like banding?
Anyway, can I have my P/N profile raised to match the new sync rate please?
Forgot to say, I have already done a router PPP session drop & reconnect.
20-05-2015 11:25 AM
20-05-2015 11:28 AM
20-05-2015 11:36 AM
Quote from: buseng12 is my line compromised in some other way like banding?
The 'Almost exact' rounded figures for each downstream sync rate (40, 44, 49, 54) suggest it's being limited by the FTTC Profile ('Banding' but not exactly like ADSL banding) and increasing in steps: http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/
20-05-2015 11:39 AM
Quote from: Matthew Your current profile is "0.128M-49M Downstream, Retransmission High - 0.128M-20M Upstream, Retransmission High" so G.INP is enabled on a high level.
You'll need to wait for this to come off to get the extra speed.
20-05-2015 12:39 PM
20-05-2015 6:02 PM
Quote from: buseng12 Or is my line compromised in some other way like banding?
Your Sync speeds do indeed appear to be increasing in the smallish, banded steps that I previously mentioned might happen.
22-05-2015 6:13 PM
- « Previous
- Next »
