Why do i have to manually re-connect to the internet?
Driver8
If I haven't been online for a few hours, my hub one router shows a solid orange status light and a solid red broadband light. I have to open my browser, go to the hub manager and enter the password and click connect, the light immediately turns blue and works fine. I haven't changed my user name or password. Does any body know what's going on?
Kdog
Fixes: 6
Re: Why do i have to manually re-connect to the internet?
Sounds like a router on the blink to be honest. Seems like the router is simply disconnecting itself, or not saving the password correctly. How old is it? If it's still in warranty I'd ask pnet for a replacement.
Fixes: 238
Sorry to hear this.
We've carried out some work which should sort this.
Can you try resetting the router using the pinhole on the back?
 Matthew Wheeler
