Which Speed Test should I use?
- Which Speed Test should I use?
11-04-2017 10:51 PM
I've used a lot of different websites and systems to test my upload and download speed and ping. I find they vary considerably.
Which is the best and most accurate? Is it BT Wholesale the one to use? http://www.speedtest.btwholesale.com/
Message 1 of 2
(987 Views)
1 REPLY 1
Re: Which Speed Test should I use?
11-04-2017 11:02 PM
The BT Wholesale one is useful especially when the further diagnostics is used.
Another good choice is Thinkbroadband as it runs 2 different tests, single threaded and multi threaded.
